Using replay gain values for volume normalization when transcoding
  • EliC
    • 1175
    Is it possible to use replaygain values for volume normalization when transcoding? Ie, flac w/ replaygain -> mp4 with normalized volume.
    • 46169
    Re: Using replay gain values for volume normalization when transcoding
    Yes, use the volume normalize dsp effect.
    • EliC
      • 1175
      Thanks, it wasnt clear if this used replaygain values or typical volume normalization techniques.
        From the DSP help file, it says that under Volume Normalize there is a "ReplayGain" choice that doesn't use tags but physically changes the file. I guess this will also use the values that are already there, or at least that is what it looks like to me.
        • EliC
          • 1175
          Once I actually downloaded and opened the volume normalizer DSP it was obvious, but from the name alone I would not have expected the number of options that are available.
          I hope that if replaygain values are already calculated it doesnt recalculate them.
