Right-click menu doesn't work
  • grillustrate
    • May 2007
    [COLOR=Navy][SIZE=3]Although the option "convert to on right-click menu" is enabled and I see it in Windows Explore shell extensions menu, it doesn't load after clicking it. I once had this issue but I can't remember how to solve it.[/SIZE][/COLOR]
    Re: Right-click menu doesn't work
    So when you click the "Convert To" option in the right-click menu, nothing happens? What version of Windows and dMC are you using?
    • grillustrate
      • May 2007
      Thanks. Windows XP and dbPowerAmp 12.
      It had already happened with version 10 or 11, I can't remember, but I solved the trouble by enabling it again in the configuration, but it doesn't work this time.
        Try r12.1, mabye?
        • grillustrate
          • May 2007
          Same. I guess it's not a matter of version. Has anybody had the same trouble here?
            Uninstall dbpoweramp music converter, reboot computer and install latest version.
