Accuraterip: how to manually set CD drive offset?
  • Dude
    • Mar 2007
    • 123
    I'm a Accuraterip beginner and I don't have a key disc for Accuraterip. I want to set my CD drive offset manually using the list of CD drive offsets: http://www.accuraterip.com/driveoffsets.htm, because I have a CD drive that is on the list.
    Where can I setup this CD drive offset in dbpoweramp reference? I can't find an option to setup the CD drive offset.
    I also had a question about ripping CD's that are not in the Accuraterip database: is dbpoweramp still be able to make accurate copies (to WAV format) when the CD you are trying to rip is not in the Accuraterip database?
    thanks in advance!
    • 45340
    Re: Accuraterip: how to manually set CD drive offset?
    You cannot, that is the point of accuraterip it self configures to make sure it is right.
    • Dude
      • Mar 2007
      • 123
      You cannot, that is the point of accuraterip it self configures to make sure it is write.
      but how can dbpoweramp make exact copies when you use a CD that is not in the accuraterip database?
      If you check "Functional Ripping Methods" here http://www.dbpoweramp.com/secure-ripper.htm , you can see every step in the audio extraction algorithm is verifyed with accuraterip.
      So my question is: what happens when you use a CD that is not in the accuraterip database?
      Does dbpoweramp just ignores all the tests with the accuraterip database and as a consequence runs all the steps in the algorithm (because every accuraterip test will have as answer "no", because you don't have used a CD that is in the accuraterip database)? How can dbpoweramp see the rip is accurate if accuraterip is not used?
      thanks in advance!
        You have to use a CD that is in the database to configure Accuraterip. Also, the CD does not need to be ripped to configure AccurateRip, a pop-up should come up and ask if you want to configure AccurateRip.
        • Dude
          • Mar 2007
          • 123
          And what if I don't have a CD that is in the database, will dbpoweramp still be able to rip CD's very well? See my previous question about the algorithm dbpoweramp executes.
          thanks
            Yes, if a CD is not in the database it does all of the steps.
            By my experience, if a CD is not in the database and Ultra Secure is enabled, dMC does 2 burst passes, 2 secure passes, and 3 Ultra Secure passes.
            • Dude
              • Mar 2007
              • 123
              Where can you see burst and secure passes in the options? I only see the option to set the number of ultra secure passes and to enable/disable ultra secure mode. There is nothing about burst or secure passes.
              So if I understand it well: when accuraterip is disabled everything is executed exactly the same as if accuraterip is enabled, but only the accuraterip check is left out?
              PS: I'm using dbpoweramp R12 reference (http://www.dbpoweramp.com/dbpoweramp-reference.htm) not the "normal" dbpoweramp CD ripper but the version for audio professionals.
              thanks in advance!
                • 45340
                Click Settings button next to the secure option.
                • mdpu
                  • Apr 2021
                  I like to buy the Melco D100 usb drive to achieve the highist accuracy in ripping. Db poweramp recognice the pioneer drive fitted in the Melco.
                  Manufacturer of the drive advises:
                  Drive offset +638 (this differs from the accurate database setting for the pioneer drive itself) due to other internal hardware differences.
                  When I click Setting button next to secure option I am not allowed to set drive offset in my reference 16.6 64 bit installation.
                  Is it possible to get these settings in the accurate rip database? I would be a shame to be forced to use EAC in the future!
                  Yours mdp
                    • 45340
                    We do not offer manual setting of the offset, sorry. That said, it would only configure to the measured drive offset using a real CD, and matching against AccurateRip. I would be inclined to believe AccurateRips determination.
