Problem converting .mp2 to .mp3
  • Mancusco
    • Mar 2007
    I copied a radio program last night using Nebula Electronics DigiTV. The original is in .mp2. I then tried to convert it to .mp3 with the result being that it plays through both Windows Media Player and Creative Media Source but at 3 or 4 times the speed. Note the resultant decreased length of the track in the Audio Properties for the 2 types below.
    I get the exact same result converting to .wav and .wma
    During the conversion process I don't get any error messages, it all appears to be working fine and going to the correct folder etc.
    Any help much appreciated.
    Sam
    Sorry for all the data that follows but though it best to include it.
    Audio properties of original copied radio program in .mp2
    Size: 81.58 MB (12% of original, 7 to 1 compression)
    Original Size: 652.67 MB
    Length: 59 minutes 24 seconds
    Channels: 2 (stereo)
    Sample Rate: 48 KHz;
    Sample Size: 16 bit
    Bit Rate: 192 kbps
    Encoder: QDesign (Guess)
    Encoder Settings: Constant Bit Rate 192 kbps
    Audio Quality: Medium (Lossy)
    Channel Mapping: Left, Right
    File: Joni Mitchell 1
    Type: Movie Clip [.mp2]
    Audio properties after converting to .mp3
    Size: 26.97 MB (12% of original, 7 to 1 compression)
    Original Size: 215.72 MB
    Length: 19 minutes 38 seconds
    Sample Size: 16 bit
    Bit Rate: 192 kbps
    Encoder: LAME 3.97
    Audio Quality: High (Lossy)
    Type: MP3 Format Sound [.mp3]
    • 46228
    Re: Problem converting .mp2 to .mp3
    Is the frequency of the source file really 48Khz?
    • Mancusco
      • Mar 2007
      Spoon - Thanks for the reply.
      Not sure about the frequency, I would have to check when I go home this evening. Could/should it be different than what is listed in the properties?
      Sam
      • Mancusco
        • Mar 2007
        I just played the source .mp2 file through dBpowerAMP and it says
        48 KHz 192 Kbps - if that helps.
          Does the file sound fine when your playing it?
          • Mancusco
            • Mar 2007
            When played in .mp2 format - yes it sounds fine. Only in .mp3 and other converted formats does it speed up.
            Sam
              • 46228
              Try converting it to wave.
              Are you using R12?
              • Mancusco
                • Mar 2007
                I had tried converting to wave with the same 'speeded up' result. Same with .wma. Yes I am using R12. :sad:
                Sam
                  • 46228
                  If you could email one file please:
                  • Mancusco
                    • Mar 2007
                    Thanks Spoon - Email should be with you.
                    Sam
                      • 46228
                      Thanks go it, will look as soon as my schedule allows.
                      • omrud
                        • Jan 2006
                        Sorry for butting in to this old thread, but I have exactly the same problem: mp2 audio recordings made by DigiTV over a Nebula DTV card, the mp2 files play perfectly on my PC (Windows Media, Nero Player), but when converted to any other format (WMA, WAV, MP3) the result is somewhere around double speed.
                        Was there a solution?
                        David
                          • 46228
                          No solution, our decoder is skipping frames, then not resyncing, there did not seem to be an easy fix.
                          • omrud
                            • Jan 2006
                            Thanks - that's a pity. I tried Audacity and it does convert the file correctly, although it's very slow. Is there any prospect of analysing what's wrong? The Amp player plays the mp2 files OK.
                            FWIW I never had any problems with mp2 files generated from my TiVo.
                            David
                              • 46228
                              Which Amp version do you have? old versions used XAudio to decode mp3.
