Errors converting FLAC to mp3 - HELP!!!
  • gustavog
    • May 2005
    • 12
    Hi, almost everytime I convert flac files to mp3 with dbpoweramp ref and batch file selector I get the following errors. I used previous versions with no problems. This started with version 12. What is going on?
    Error converting to mp3 (Lame), 'P:\Belle & Sebastian\Boy With The Arab Strap, The\09 - The Boy With The Arab Strap - Rock.flac' to 'Q:\iPod\Belle & Sebastian\Boy With The Arab Strap, The\09 - The Boy With The Arab Strap.mp3'
    Unable to read from File 'P:\Belle & Sebastian\Boy With The Arab Strap, The\09 - The Boy With The Arab Strap - Rock.flac'
    md5 did not match decoded data, file is corrupt.
    Error converting to mp3 (Lame), 'P:\Belle & Sebastian\Boy With The Arab Strap, The\12 - The Rollercoaster Ride - Rock.flac' to 'Q:\iPod\Belle & Sebastian\Boy With The Arab Strap, The\12 - The Rollercoaster Ride.mp3'
    Unable to read from File 'P:\Belle & Sebastian\Boy With The Arab Strap, The\12 - The Rollercoaster Ride - Rock.flac'
    Error converting to mp3 (Lame), 'P:\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\02 - One Word - Other.flac' to 'Q:\iPod\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\02 - One Word.mp3'
    Error: Watchdog timeout, possible CoreConverter crash
    Error converting to mp3 (Lame), 'P:\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\04 - Empty Frame - Other.flac' to 'Q:\iPod\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\04 - Empty Frame.mp3'
    Error converting to mp3 (Lame), 'P:\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\05 - Cordoba - Other.flac' to 'Q:\iPod\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\05 - Cordoba.mp3'
    Error opening file 'P:\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\05 - Cordoba - Other.flac' check no other program has it open. [clDecoder::Open]
    Error converting to mp3 (Lame), 'P:\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\06 - Spinning Away - Other.flac' to 'Q:\iPod\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\06 - Spinning Away.mp3'
    Error opening file 'P:\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\06 - Spinning Away - Other.flac' check no other program has it open. [clDecoder::Open]
    Error converting to mp3 (Lame), 'P:\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\07 - Footsteps - Other.flac' to 'Q:\iPod\Brian Eno & John Cale\Wrong Way Up (2005 Remaster)\07 - Footsteps.mp3'
    Re: Errors converting FLAC to mp3 - HELP!!!
    Can you convert the files one folder at a time?
      • 46171
      In dbpoweramp configuration >> codecs >> advanced you can set how to handle flac errors, I am sorry to say your flac files look corrupted.
      • gustavog
        • May 2005
        • 12
        I did one track and got no error. The track I did was the one that previously yielded this error:
        • Teknojnky
          • Dec 2006
          • 323
          I think this happens when EAC (or whatever other programs) put id3 tags in flacs and the encoder freaks out. The 1.1.3 flac command line encoder has a problem with this as well when doing flac to flac encodes (ie from 1.1.2 to 1.1.3 files.
          check this thread for more detailed info:
          when i find files with this problem, I use mediamonkey to re-encode flac to flac, then use the script in the thread above and/or dbpoweramp to do whatever I need done (doing replay/album gain primarily).
          Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
          Want a random mode based on track and artist relationships?
          [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
          [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
            • 46171
            It shouldnt be the tags, id3v2 was once part of flac, and our decoder should read them ok.
            • cyphera9
              • Jul 2010
              • 8
              Hey, I've experienced the same problem mentioned in this thread just recently when converting flac to mp3 vbr. Between 2 and 5 tracks every album show up the error 'md5 did not match decoded data, file is corrupt.'
              I tried converting errored tracks again individually but with the same error. Followed Spoon's advice and change the following setting
              Corrupt Flac File - Continue Decoding (Show Error as Information)
              Now the tracks convert, show no errors and where previously the errors would result in mp3s that were cut short, now the tracks I have checked so far seem to play fine all the way to the end.
              Am i safe to leave this setting like this or will this cause other errors to be ignored and missed? I'm confused as to why this problewm occured very suddenly and is resolved changing this setting.
              Any advice would very much be appreciated.
              Cheers
              • cyphera9
                • Jul 2010
                • 8
                As a follow up, I have listened to an album which wouldn't convert before I changed the above setting and it is very jumpy where as the original flac is fine.
                Can you recommend what the problem may be?
                • Teknojnky
                  • Dec 2006
                  • 323
                  it simply means your file is corrupt.
                  there is no way to know how it got corrupt, but if the md5 doesn't match, then the file is basically junk and needs re-ripped.
                  in my experience, md5 errors are caused by drive errors, especially on external drives.
                  you could try run chkdsk to try to repair and prevent more errors, but any files which are already corrupted can't be fixed.
                  • cyphera9
                    • Jul 2010
                    • 8
                    Nightmare, Thanks for clearing that up. I will try and figure why this is happening.
                    All the best!
                    • hullabaloo
                      • Aug 2010
                      I was having the exact same problem. I couldn't convert a few FLAC files to any other format (and my cd was beyond repair so I couldn't rip again), and I was getting the same errors you described. I was able to get Ashampoo Music Studio 3 to burn the FLAC files to a disc and then I could re-rip them.
                        • 46171
                        The files you burnt had the errors, nothing can magically correct errors in FLAC files if the MD5 does not match.
