RAW MP2 vs BWF MP2 problem
  • _mike_
    • Oct 2006
    Hi!
    I'm having this problem with bwf-mp2 -files. In our production editor they seem to have now soundform (graphic) at all. But when I convert them with dbpoweramp from bwf->mp2 they are allright.
    My question is: Is this conversion lossless or not? And if it is lossless, then how can I convert (aka rip of all BWF-stuff) without any loss in stream itself.
    Re: RAW MP2 vs BWF MP2 problem
    Conversion will be lossy (ie it is decoded and re-encoded), R12 (which does not support bwf or mp2 encoding) is able to preserve the riff chunks through conversion, those codecs are a few months away.
    • _mike_
      • Oct 2006
      Sorry to reask... but. How am I supposed to rid of riff-chunks in bwf? I want to make conversion from BWF to raw MP2 without re-encoding?
      Question 2:
      If you are saying that I can not encode these files with upcoming R12 then I definetly are not upgrading... Are you about to implement that conversion to this new version...
        Try googling for "strip wave header"
        I refered to the current status of R12 alpha, there are many codecs still missing, and will be added in the next number of months.
        • _mike_
          • Oct 2006
          Thanks... now I have ripped those headers... I have only the raw data-part of that file... But still our broadcasting software can not show the waveform. It plays file fine but the waveform is just plain blue block...
          I have even tried to set MPGEpmhasis bit inside this raw-file. That doesn't help ......
          What can be so odd in this stream?
            I have not used your other software so cannot comment on what it needs.
            MpgEpmhasis is something very old and no longer used (like audio cds with the emphasis bit set).
