problems converting to mp3
  • c0rl0
    • Aug 2006
    hi,
    i'm got dbpoweramp music converter to rip cds to mp3s. whenever i try to convert to mp3s i get the following error: "codec compression error"... this happens about half way through the conversion. the conversion dies and then i'm left with a partial mp3, which will play up until the point that the conversion crashed. not sure what the issue is... any ideas? i'm using v11.5
    Re: problems converting to mp3
    You mean that happens half-way through ripping a cd or halfway through ripping the first track?
    And are you using dMC Audio CD Inout or dMC alone?
    What settings are you trying to use for the mp3's?
    Any DSP effects applied automaticlaly to everything?
    Are you using it while signed in as administrator?
    Registered or unexpired trial version of the converter and powerpack?
    If you rip to uncompressed wav instead, does it work?
    • c0rl0
      • Aug 2006
      sorry for taking so long to get back to you....
      half way through first track (any track)
      dMC alone
      i tried all different settings, but currently using variable bitrate bet 128-320
      no DSP effects
      yes.
      registered w/ powerpack
      i did a wma and it didn't work
      it worked before i reformatted windows. it's being really weird.
        • 46229
        Try using Audio CD input and rip to wave, if any messages please report the full message here.
        • c0rl0
          • Aug 2006
          no problems converting from a cd to wav.
          when i convert from cd to mp3, i get the following:
          errors whilst converting:
          CODEC compression error.
          obviously it's displays the error for each track.
          i also get the same error when attempting to convert from wav to mp3.
          thanks for your help!! again, sorry for the delay...
            What compression settings are you using for mp3?
            • c0rl0
              • Aug 2006
              variable bitrate... min: 128Kbps, max: 320Kbps
              channels: stereo, frequency: 44100
              i've tried using a constant bitrate with no luck either.
              thanks...
              shawn
                Is this error message for all of your CDs or just this one? If it is just this CD, what is the name of the CD?
                • c0rl0
                  • Aug 2006
                  all of my cds
                    It looks like maybe your mp3 codec is somehow corrupted.
                    There may be inteference with some other audio or even video software you have which may have modified the codec. Could you take some inventory?
                    • c0rl0
                      • Aug 2006
                      i thought that might be the issue, so i replaced the lame codec with a fresh copy. i really don't have much other than nero, and even that was installed after i installed (and tried to get working) dbpoweramp.
                        • 46229
                        Try the new R12 alpha in the beta section of this forum (the cd ripper for r12 is a major step forward).
                        • c0rl0
                          • Aug 2006
                          r12 alpha worked great. i'm not sure what the difference is, but it worked. thanks
