Slight problem converting to wma -
  • savagcl
    • Aug 2004
    • 439
    A search didnt really show this problem (at least that i could find).
    Problem:A WMA file with these settings:
    size =504kb
    Original size =15642kb
    length =2min 05seconds
    compression =31 to 1
    Frequency = 32000
    Channels = 2
    Bits = 16
    Will convert to a Wave file but i only get 60 or 83 kb as output.
    Conversion settings i have tried:
    1. Output as Wave, 16 Bit, 44100Hz (CD), 2 Stereo(CD).
    2. Wave, Bits as source, Freq as source, Channels as source.
    3. Using the "Change Format" as CD Quality, Format:PCM, Attributes: 44.100kHz, 16 Bit Stereo, 172kb/sec.
    After converting it to a wave file the size shows 60kb/83kb.
    I will hear the first note during playback (only).
    Note: I have both WMA V9.1.dll and WMA V9.dll installed.
    My dB configuration is:
    Version Information
    dBpowerAMP Music Converter: Release 11.5
    Power Pack & Mp3 License: [ Registered: Yes ]
    dBpowerAMP Audio Player: Release 3 Beta 6
    dBpowerAMP CD Writer: Release 2 [ Registered: Yes ]
    Sveta Portable Audio: Not Installed 'enhance your portable player'
    Contact Information
    Web Site: http://www.dbpoweramp.com
    Support: http://www.dbpoweramp.com/support.htm
    Support Forum: http://forum.dbpoweramp.com
    Codec Central: http://www.dbpoweramp.com/codec-central.htm
    Add extra [en/de]coding abilities such as m4a, wma, etc.
    Smart Install Codecs
    Flac: .flac
    OptimFROG: .ofr
    Shorten: .shn
    WavPack: .wv
    Advanced Audio Compression: .aac
    ===Shell Integration===
    Convert To (right click): On
    Edit Tag (right click): On
    Popup information Tips: On
    Explorer ID Tag Property Page: On
    Explorer Columns: On
    ===Codecs===
    Installed Compression Codecs (Write)
    Audio cd
    Mp3 (Lame): Lame Version 3.96.1 [ .mp3 ]
    Musepack mpc (CLI): Release 5 [SV7 1.15v] [ .mpc ]
    Ogg Vorbis (CLI): [ .ogg ]
    Ogg Vorbis: Release 12 (Ogg V1.1.0) [ .ogg ]
    Real Audio: Release 3 [ .rm ]
    Test Conversion (No Write)
    Wave: [ .wav ]
    Windows Media Audio V9.1: Release 1 [ .wma ]
    Windows Media Audio V9: Release 2 [ .wma ]
    Installed Input Codecs (Read)
    Auxiliary Input Decoder: .aux
    CD Input Decoder: .cda
    DirectShow Decoder: Release 1 .wma; .cda; .wav
    Midi Input Decoder: .mid; .midi
    Mp3 Input Decoder: .mp3; .mp2; .mpga; .mpa; .mpx; .mpg; .mp1
    MPC Decoder: .mpc; .mpp; .mp+
    Ogg Vorbis Input Decoder: .ogg
    Real Audio Input Decoder: .ra; .rm; .ram
    Wave Input Decoder: .wav
    Winamp Input Adaptor: .APE; .MAC; .APL; .CDA; .ack; .ack; .M4A; .MP4; .MPC; .MP+; .MPP; .MP3; .MP2; .MP1; .RMP; .NSV; .NSA; .MOV; .QT; .OGG; .WMA
    Windows Media Audio Input Decoder: .wma; .asf; .wmv
    ===Options===
    dBpowerAMP Reference Options
    Pro. Frequency Conversion: On (slower but high quality)
    Mp3 Input Decoder
    CRC Errors: Ignore
    Decode To: 16 bit (dithered)
    Wave Compression Codec
    More than 16 bit or 2 Channels: Write WaveFormatEx Header
    ===ID Tag Options===
    Mp3
    Tag Creation: ID3v2 & ID3v1
    Write ID3v1 Version: v1.1
    ID3v1 UTF8 Read: Yes
    ID3v1 UTF8 Write: No
    Write ID3v2 Unicode: No
    Write ID3v2 Version: v2.3
    Ogg Vorbis
    Uppercase Tag Elements: No
    Windows Media Audio
    Write Track Number as: WM/TrackNumber
    I'm not sure what i'm doing wrong and could use some aid.
    thanks,
    savagcl
  • savagcl
    • Aug 2004
    • 439
    Re: Slight problem converting to wma -
    Darn!! Forget it.
    When i converted straight to mp3, it worked fine.
    So, i guess converting a WMA to Wave is just not done (or possible)???
    thanks anyway,
    savagcl
    • savagcl
      • Aug 2004
      • 439
      Nope, I'm wrong, the convert to mp3 didnt work either (i converted the
      wrong folder). :o :o
      While the wma did convert to mp3, the output sizes were way to small.
      Back to first message, this thread. Sorry, my bad.
      savagcl
      • Oceansway
        • May 2006
        savagcl
        Maybe you shouldn't have two wma plugins installed
        If you have XP use tthe 9.1
        I am not shure if this is the problem, but I had problems when only 9.0WMa Plugin was installed. So may be this is the problem
        EDIT:
        Why is it only 172kb/sec. :shocked:
        Shouldn't it be much more?
        • savagcl
          • Aug 2004
          • 439
          I have both installed already.
          From config:
          thanks,
          savagcl
            • 46171
            Windows Media Player can play the wma file ok?
            • savagcl
              • Aug 2004
              • 439
              Spoon,
              See the thread "Wave conversion problem". This fixed both wma and wav
              problems.
              thanks,
              savagcl
                See here: http://forum.dbpoweramp.com/showthread.php?t=10564
                And try to keep like-posts and threads together.
