installation problem please help
  • pazamato
    • Mar 2006
    Ive installed (or rather tryed to install and run) dBpowerAMP-r2.exe
    The install program seems to run to completion. I get to install preferences and configuration. But when I press the "Run dbPowerAmp" I get the following error message(s).
    1) Amp.exe has generated erros and will be closed by windows.
    You will need to restart the program. An error log is being created. ok.
    I have reinstalled the dBpowerAMP-r2.exe hoping to workaround the error, but then recieve the following error.
    2)Application popup: dBpowerAMP : Setup has detected an older version of dBpowerAMP.
    Uninstall old version before installing new [recommended]?
    I initiate the required/recommended uninstall before the 2nd reinstall. And at the end of the 2nd install, I get the initial error.
    Which is error 1) Amp.exe has generated erros and will be closed by windows.
    Can anyone help work through the rough installation?
    Re: installation problem please help
    Try this: http://forum.dbpoweramp.com/showthread.php?t=6828
    And then use the link in my signature below to download the latest dAP beta. Don't worry, its worked just fine for me even though it IS a beta. It being beta just doesn't mean Spoon wants to make it a full release yet and is still working on adding features to it.
