Help? Recording iTunes using DMC Auxliary Input - followed directions and read FAQ...
  • moppet52
    • Mar 2006
    Hello,
    I have some iTunes 6 music that I am trying to record and convert using dmc auxiliary input. I downloaded the DMC Power Pack and MP3 Encoder trial version and attempted to use DMC Auxiliary Input to record these files.
    I read and follwed the instructions found here: http://forum.dbpoweramp.com/showthread.php?t=7318
    However, every time I reach step #4 (hit the record button) DMC Auxiliary input displays the following error:
    "The CODEC required to decompress '\\Aux\Track01.aux' could not be opened."
    I was unable to find what might be causing this problem and was hoping for some help.
    TIA for any information.
    Moppet52
    Re: Help? Recording iTunes using DMC Auxliary Input - followed directions and read FAQ...
    Check your compression settings. Normally that results when you are trying to record to a 24-bit file, which Auxiliary Input cannot do.
    • moppet52
      • Mar 2006
      Tada! That did it... no more error message.
      Thanks!
