problem converting mp3 to mp3 with abr and 22khz sampling rate
  • niemand0815
    • Mar 2006
    i tried to convert some 22khz frequency 128kbit mp3 files to 64kbit mit abr.
    but this resulted in the error:
    The CODEC required to compress 'c:\whateverfile.mp3' could not be opened.
    Error creating mp3 compressor, try different encoding frequency and bitrates.
    after several other option i changed the sampling rate to 44khz and voila, everything worked.
    strange enough, when using cbr i can also use a sampling rate of 22khz without any problem.
    is this a normal behaviour (is abr only able to use 44khz?) or is this a bug?
    Re: problem converting mp3 to mp3 with abr and 22khz sampling rate
    Lame can be funny about bitrates / frequencies, I cannot comment on wether it is a bug or not (about to release a newly rewritten lame encoder that has been well tested), keep your eye on the r12 alpha thread.
    • gameplaya15143
      • Sep 2005
      • 276
      it should work fine
      try the lame.exe cli plugin
      --abr 64 --resample 22
