CD DTS (DTS Audio) to standard DTS
  • jaban
    • Mar 2006
    I found this text:
    HOW TO EXTRACT CD DTS (DTS AUDIO) TRACKS:
    1) download DBPOWERAMP Music Converterand and install
    dBpoweramp: mp3 converter, FLAC, WAV, AAC and Apple Losslesss. CD Ripper, Album Art, Asset UPnP Server, Image Converter, Video Converter, PerfectTUNES, AccurateRip
    2) select DbPowerAmp Music converter from the Start menu
    3) Load CDA file from CD with the following parameters:
    - converting X file to WAVE
    - bit as source
    - freq as source
    - channels as source
    4) click "convert"
    The tracks gets extracted into a non-standart wav file. It's actually a DTS wav. You can burn the file on a CD or a DVD with Nero, for example. It is decoded as a standart 5.1 DTS file from any DTS decoder.
    I have some DTS-CDs wich must be played in a DVD-player (with DTS-decoder). Is it possible to rip & convert to a standard waw-file so that it can be burned CD onto CD that will be playable an a standard CD-player???
    0
    Option 1
    0%
    0
    Option 2
    0%
    0
    The poll is expired.
    Re: CD DTS (DTS Audio) to standard DTS
    If you can find software that will play your file on your computer, you can use Auxiliary Input to record the song as you play it. You can then take the resultant file and convert it to whatever your heart desires. Instructiosn below.
    • jaban
      • Mar 2006
      Thanks, I will follow the "Auxiliary Input Instructions"
        Out of my curiosity, what is the poll supposed to mean? If you put it on there by mistake or just mistyped the lables, I don't think you can fix it but I can fix it for you. I can also take it off if it was just a mistake.
