Been trying to install the M4A codec alongside all my other DMC stuff, which sits in a specific subdirectory on my laptop. Everything installs fine, but when I try to convert a file using the codec, DMC or Sveta seems to expect the faac file to sit in a specific location on my PC ie in the Program files directory ie
C:\Program Files\Illustrate\dBpowerAMP\Compression\m4a (FAAC CLI)\faac.exe
- not with the rest of the DBPoweramp stuff
Unfortunately my company locks down its laptops so we can't mess around with the configuration much, so everything I want to do has to sit in my "personal area".
Is this a bug in the installation programme, as it does ask you where you want to put the files and I am sure that not everyone takes the default :-)
Doug
Doug
