Help with CD rippper naming
  • LaMujer
    • Jun 2004
    I had to reinstall CD Ripper when the computer I'd been using it on for ages crashed. I now find I can't adjust the naming I get a "stock" coding and I can't find a way to manually enter the codes I want. Would be grateful for any help!
    • 6189
    Re: Help with CD rippper naming
    lower left of cd ripper screen, on the naming "row" you click SELECT to the right and then create or edit your naming string. There's instructions at:
    I use this on my windows machine. Handles various artists, multi disks, single disks, album artist or just artist. (this is windows. for Mac replace backslash with forwardslash)
    • LaMujer
      • Jun 2004
      Thanks for the reply! When I posted this yesterday, clicking on SET (not SELECT on my Windows 11 installation), did not bring up the screen allowing me to set code choices manually. For some reason it works today!! I'll hope things stay as promised now.
