Problems ripping
  • GEB
    • Apr 2014
    • 9
    Problems ripping
    Hello From France,
    I have a more frequentproblem that happens more and more often (50% of CD, and not on all files): it makes re-rip of certain files for long long duration with dozens of thousands frames, before giving a final error.
    Doing with burst option fixes badly the pb because the sound is then not good, and there still remains final errors on certain files.
    Thanks for youy help.
    Window 10, 64 bits, CD reader external.
  • GBrown
    • Oct 2009
    • 422
    Re: Problems ripping
    Originally posted by GEB
    I have a more frequent problem that happens more and more often (50% of CD, and not on all files): it makes re-rip of certain files for long long duration with dozens of thousands frames, before giving a final error.
    If there are playback errors after using Burst mode, then there are errors in the rip. Using Secure mode may help to try and re-read the bad sections. Especially if there are thousands of frames reported, there is either a very bad scratch, or the disc may be dirty or even deteriorating.
    • GEB
      • Apr 2014
      • 9
      I captured the screen : jpeg file is attached
      • GEB
        • Apr 2014
        • 9
        Thank you Gbrown for your answer.
        Unfortunatly it happens on most CD, And no scratch at all can be seen on CDs.
        Secure mode gives majority error.
        It was not possible to put a jpeg 80K image in the attachement manager to show you the screen.
        Best to you.
        • GBrown
          • Oct 2009
          • 422
          Best to you.
          Does any other software rip any of these discs without noise?
          • GEB
            • Apr 2014
            • 9
            Thanks Gmarron for your answer.
            Do you have any suggestion for an other software to use for that ?
            • GBrown
              • Oct 2009
              • 422
              Depends on your OS. You can try Windows Media Player or iTunes to see if they work at all. But the won't be able to provide accurate rip results or proper error correction like dbPoweramp can.
                • 1914
                Are C2 pointers enabled or disabled?
                  • 46198
                  Disable C2 pointers if enabled, your drive does not appear to support them.
                  If not, then replace the CD drive.
                  • GBrown
                    • Oct 2009
                    • 422
                    Originally posted by simbun
                    Do NOT use WMP or iTunes, given you've said you're on Windows use Exact Audio Copy or CUETools; both come with AccurateRip and CTDB verification.
                    Given you say it's happening on most rips have you tried switching cables?
                    I wasn't suggesting to use these permanently, just to confirm if the any other software would work at all. This was simply a suggestion for widely accessible options.
