CD Ripper 17.4 just hangs on rip. CD-ROM drive doesn't start read.
  • Arkiados
    • Nov 2006
    I blanked out the title and content. It gets the metadata just fine. See attached.Click image for larger version
    Re: CD Ripper 17.4 just hangs on rip. CD-ROM drive doesn't start read.
    You cannot not have a title, as that is used to create each filename.
    • Arkiados
      • Nov 2006
      I mean I blanked out the pic of what I was ripping but all the fields and metadata are populated. I click rip and it just sits there. The drive doesn't engage. Been using on the same comp for a decade. The drive works fine though.
        Change the encoder to 'Test Conversion', does it rip the cd then?
        • Arkiados
          • Nov 2006
          Yes
            Look at the file names and ensure the locations where the tracks are to be written exists and has write permissions
            • Arkiados
              • Nov 2006
              I cleared the HKCU keys. If I select just FLAC for example, ripping works. But multi-encoder does not work.
                • 1932
                You have to specify a namestring and destination for each and every encoder.
                  Remove your two encoders and re-add them, buy default naming is set to match CD Rippers naming which is:
                  [MAXLENGTH]80,[IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][][][]\[MAXLENGTH]80,[album][]\[MAXLENGTH]80,[track] [artist] - [title][]
                  if you need to change the base location at the top of the naming page (choose Output To >> edit dynamic naming).
                  • Arkiados
                    • Nov 2006
                    Remove and re-add encoders and it now just doesn't rip like before.
                    • Arkiados
                      • Nov 2006
                      FYI. Re-installed r16.6. Works fine.
                        What security software do you have?
                        • Arkiados
                          • Nov 2006
                          Windows Defender
                            Try safemode with networking, ensure you are ripping to a local drive.
                            Does that work. Also only have 1 encoder in multi-encoder, a wave encoder.
