Problems writing FLAC after ripping discs
  • Wizzy_Wiz
    • May 2021
    Good evening,
    I've been ripping my entire collection and have half a dozen discs out of maybe 400 so far that exhibit this problem.
    The tracks seems to rip but won't write giving this error:-
    Error ripping to FLAC, 'Track 1' to '\\nas\music\Pet Shop Boys\Please\01 - Two Divided By Zero.flac'
    Error writing to temporary file (Win:0): [dBCoreConverter::HandleNonLiveDSPs]
    It doesn't appear to be a problem with the mapped drive that's been written to - all the other CD's so far have no issues.
    I've a couple of drives in my PC (ASUS BW-16D1HT + Sony Optiarc DVD-RW AD-7260S) and the same happens with both - so I'm suspecting some kind of copy protection on the CDs?
    Can anyone point me in the right direction?
    Many thanks,
    • 46160
    Re: Problems writing FLAC after ripping discs
    The error relates to writing a temporary file, what DSP effects are you using?
    • Wizzy_Wiz
      • May 2021
      Hi Spoon,
      I did have the Replay Gain on - but even when I remove it, the same error occurs.
        • 46160
        Close CD Ripper, run dbpoweramp control center >> Advanced
        right at the end is an option to enable debug mode, enable it, rip just 1 track from a cd and close CD Ripper. Log file(s) will appear, copy and paste them here please.
        • Wizzy_Wiz
          • May 2021
          Hi Spoon,
          Thanks for your time.
          Here's the log
          Splitting Command Line:"C:\Program Files\dBpoweramp\CoreConverter.exe" -dbcmd=C:\Users\******\AppData\Local\Temp\dBT40C.tm p
          ->-> [dBCoreConverter::ReaddBCommandFile]
          <-<- [dBCoreConverter::ReaddBCommandFile]
          Allying to Processor 1
          ->-> [cldBCodecHandler::LoadEncoder]
          Loading Encoder 'C:\Program Files\dBpoweramp\encoder\FLAC.DLL'
          <-<- [cldBCodecHandler::LoadEncoder]
          BatchID [clEncoder_FLAC::Set]
          ->-> [dBCoreConverter::StripCoreConverterCmds]
          <-<- [dBCoreConverter::StripCoreConverterCmds]
          SendRawUnCompressed [clEncoder_FLAC::Get]
          IsLive [clDSP::Get]
          SendOverReplayGainTags [clDSP::Get]
          BatchID [clDSP::Set]
          IsLive [clDSP::Get]
          Communicate [clEncoder_FLAC::Get]
          ->-> [dBCoreConverter::OpenDecoder]
          Reading StdIn Tmp File IDTags: Read
          Using StdInput WFX:Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
          <-<- [dBCoreConverter::OpenDecoder]
          SendOverReplayGainTags [clEncoder_FLAC::Get]
          *** Error: Error writing to temporary file (Win:0): [dBCoreConverter::HandleNonLiveDSPs]
          ->-> [clDSP::BeginConversion]
          Calculate Trackgain: No
          Calculate Albumgain: Yes
          R128 Calculation: Yes [-18 LUFS] [clDSP::BeginConversion]
          <-<- [clDSP::BeginConversion]
          ->-> [clEncoder_FLAC::BeginConversion]
          Converting to '\\nas\music\Pet Shop Boys\Please\01 - Two Divided By Zero._' encoder settings ' -application="CD Ripper" -compression-level-5'
          FLAC Compression Level: 5
          <-<- [clEncoder_FLAC::BeginConversion]
          Encoding To: FLAC
          Encoder Cmd Line: -application="CD Ripper" -compression-level-5
          DSP Effects:
          Audio CD - De-emphasis (non-live):
          ReplayGain: -albummode="0" -notrackgain -r128lufs="-18" -maxtgain="25 dB"
          ->-> [dBCoreConverter::CloseDecoder]
          <-<- [dBCoreConverter::CloseDecoder]
          ->-> [clDSP::EndConversion]
          Loudness=nanLUFS, TruePeak=-infLUFS [clDSP::EndConversion]
          *** Information: Silence track detected, ReplayGain track tag not generated, track gain 0.00dB [clDSP::EndConversion]
          <-<- [clDSP::EndConversion]
          ->-> [clEncoder_FLAC::EndConversion]
          <-<- [clEncoder_FLAC::EndConversion]
          File Size Check : 29581 bytes Filename: \\nas\music\Pet Shop Boys\Please\01 - Two Divided By Zero._
          File Size Check (before ID Tags Written): 29581 bytes Filename: \\nas\music\Pet Shop Boys\Please\01 - Two Divided By Zero._
          ->-> [dBCoreConverter::IDTagWriter]
          Decodes [clDecoder::Get]
          IDTags [clDecoder::Set]
          ->-> [clDecoder::WriteIDTags]
          Opening file '\\nas\music\Pet Shop Boys\Please\01 - Two Divided By Zero._' for write access: Opened
          ->-> [clDecoder::Open]
          Opening file '\\nas\music\Pet Shop Boys\Please\01 - Two Divided By Zero._' for read access: Opened
          Init FLAC:
          Reading Meta Data:
          contained 0 tags:
          ->-> [clDecoder::ReadIDTags]
          <-<- [clDecoder::ReadIDTags]
          <-<- [clDecoder::Open]
          ->-> [clDecoder::Close]
          <-<- [clDecoder::Close]
          <-<- [clDecoder::WriteIDTags]
          <-<- [dBCoreConverter::IDTagWriter]
          ->-> [clDSP::AfterConversion]
          <-<- [clDSP::AfterConversion]
            • 46160
            You have this DSP effect:
            Remove it.
            • Wizzy_Wiz
              • May 2021
              Thanks Spoon,
              The effect wasn't obviously been applied, so I reset all and this has solved my problem.
              Many thanks for your time :-)
