Help with "Output to" in CD ripper
  • witty4m_name
    • Mar 2018
    Hi, first post here on this very helpful forum. I'm using CD ripper reference and have a quick question regarding how my .flac files are names/stored.
    Here is an example of one of my ripped .flac files:
    D:\Music\JRiver\Music\Chris Thile\Not All Who Wander Are Lost\02 Chris Thile - Wolfcreek Pass.flac
    You see, I have 'Music' in the file name twice which is redundant. How do I get it to output the files straight into the 'JRiver' subfolder and then sorted into artist and album?
    Then, if I change this, will it mess up things with all the other albums that I have already ripped and saved like the one above?
    Thanks!
    • 46230
    Re: Help with "Output to" in CD ripper
    Existing albums are not changed.
    What do you have set in the Path and Naming Boxes?
    • witty4m_name
      • Mar 2018
      I have this in the "Output to" box: Music\JRiver\Source path\Source filename
        Are you using [Multi Encoder] then, if you are using the "Output to" box?
        • witty4m_name
          • Mar 2018
          Yes, I'm using the multi encoder. I only want this file naming changed for the .flac encoding going to JRiver folder.
            • 1915
            Hey witty4m_name,
            first off: you have to specify a output path for each and every encoder in its settings.
            This output "D:\Music\JRiver\Music\Chris Thile\Not All Who Wander Are Lost\02 Chris Thile - Wolfcreek Pass.flac" is no surprise for your naming string "Music\JRiver\Source path\Source filename".
            "Music\JRiver" -> "Music\JRiver"
            "Source path" = "Music\Chris Thile\Not All Who Wander Are Lost"
            "Source filename" = "02 Chris Thile - Wolfcreek Pass"
            So you see that naming string will not produce what you want.
            You have to use a naming string like
            Base location = "D:\Music\JRiver"
            Dynamic naming = "[album artist]\[album]\[track] - [title]"
            • witty4m_name
              • Mar 2018
              Ok, thanks Dat Ei, I will give that a try and see if it outputs the files where I want.
              • witty4m_name
                • Mar 2018
                Worked perfectly with the new string you provided. Thanks again!
