Basic Ripping Problems
  • sparks01
    • Jan 2018
    Over the last few weeks I have been using the 21 day trial to rip my cd's in flac to my synology nas drive without any problems.
    In the last few days (when I have continued to rip my cd collection) I have noticed that the ripper is still ripping but when I come to play the tracks only
    the first ten seconds play. I have also noticed that the file size for each track is a fraction of a normally ripped track.
    As a test I have tried ripping in wave instead of flac but this resulted in the same errors.
    To check there was no problem with my cd drive I ripped a cd to i tunes with no problems.
    Thinking that the problems were due to the expiry of my 21 day trial I decided to subscribe to dBpoweramp and Perfect Tunes.
    To my disappointment this made no difference - the same problems remain.
    Hopefully there is a simple solution to my problem.
    Can anyone help.
    Re: Basic Ripping Problems
    Which version of dBpoweramp and PerfectTunes, Windows or Apple?
    Try ripping a CD to a local hard drive. Is the result the same?
    • sparks01
      • Jan 2018
      Thanks for the reply.
      I am using the Apple versions.
      To hopefully shed some light on the problem I have done the following :-
      1) Using iTunes as the ripping software I have ripped to my MacBook Pro hard drive and to my Synology nas drive.
      Result - in both cases the tracks have ripped correctly and play without any problems.
      2) As above - this time using dBpoweramp as the ripping software.
      Result - problems outlined in my opening post. Tracks play for exactly ten seconds and are not the size of a correctly ripped track.
      When ripping with dBpoweramp the ripping status comes up with a green tick complete description within a few seconds followed by an accurate (38) description.
      Conclusion :
      I think I have proved that there isn't a problem with either my Apple cd drive or Synology nas drive.
      There doesn't seem to be a problem with the iTunes ripping software.
      The problem seems to point towards the dBpoweramp software.
      But why did everything work during my initial trial period - what has changed ?
      Confused!
      Regards.
        Are you able to answer my second question in post no. 2?
        • sparks01
          • Jan 2018
          Hi mill.
          Can you explain what you define as a local hard drive ?
          Does the MacBook Pro not qualify as a local hard drive ?
            • 1914
            A local hard drive is a hard drive that is directly connected to your computer (via SATA, USB, FireWire) and not via network (i.e. NAS, SAN, Cloud).
            That is not a question of the computer itself but of the Connection between computer and storage.
              • 46198
              Look on the DSP effects tab in CD ripper, there should be no effects listed.
              • sparks01
                • Jan 2018
                Hi Spoon.
                I have cleared the DSP effects tab and I think that has solved the problem !
                I am bemused that such a change can have such a dramatic affect on ripping.
                There is no mention of this in the set up guide.
                Thanks for your help and all the other replies I have received.
                Regards.
                  Hi Spoon.
                  Regards.
                  Which DSPs were you using?
                  • sparks01
                    • Jan 2018
                    I wasn't aware I was using any DSPs !
                    I went from the trial version to the registered reference version without changing anything in the DSP tab.
                    Maybe in my frustration to solve my problems I may have changed a setting by mistake.
                      I am slightly confused as you said in post no. 9:
                      DSPs are added and configured manually, by the end user.
                      So, you didn't add any DSPs and all is working OK now?
                      • sparks01
                        • Jan 2018
                        I am currently ripping cd's as we speak with no DSPs - everything appears to be working ok.
                        I have no real interest in adding DSPs.
                        The only thing I corrected, as Spoon suggested, was to clear DSPs and this magically solved my problems.
                          You might want to consider using the ReplayGain DSP.
                            • 6189
                            Agree. That's the only one I use when ripping to FLAC.
