dBpoweramp - strange goings on with CD ripping - Help!
    Re: dBpoweramp - strange goings on with CD ripping - Help!
    Originally posted by Dat Ei
    If you use a Windows System (Windows 7 or newer) you can use the Windows inherent tool "robocopy", which is a very powerful tool...
    Thank you Dat Ei, for the excellent info.
    Have you tried using the .bat file within Task Scheduler?
      • 1932
      #47
      No, actually not. Usually I rip a batch of CDs and at the end of that I just double-click my batches.
      As long as your network connections are established, I don't see a point, why those batches will not work and start if they are invoked by the task scheduler.
        nice tutorial on robocopy. Seems very useful. I've historically been using freefilesync to keep my main library files synched to my various backups.
        p.s. I think the OP is a Mac user.
        • MrWriter
          • Nov 2017
          • 35
          #49
          Yup, Mac user.
