dBpoweramp - strange goings on with CD ripping - Help!
  • MrWriter
    • Nov 2017
    • 35
    I've successfully imported about 850 of my 1000 CDs, however, the remaining 150 or so won't import.
    CDs just keep having errors and CD ejects with loads of issues.
    Like I said, I've ripped over 800 with no problem, just about 150 or so that won't rip.
    Is it to do with some sort of piracy encryption that these particular CDs have perhaps?
    All the CDs are brand new with not even a fingerprint on them, I really look after my CDs.
    I am using a brand new iMac with latest os and latest dBpoweramp and an external USB Apple CD drive. However, I bought a different make/model CD drive off Amazon to see if that was the problem, it isn't, both different CD drives do the same thing.
    Could it be a dBpoweramp setting? not sure it is though as I've imported about 90 percent of my CDs just fine.
    • 1932
    Re: dBpoweramp - strange goings on with CD ripping - Help!
    Any error messages?
    • MrWriter
      • Nov 2017
      • 35
      With a regular rock/pop CD that has an average of 12 to 12 tracks. What happens is dBpoweramp takes an age with ripping just the first track. It takes about 5 minutes just to get 25% of the way through the first track, then about another 10 minutes to get to the end of first track, which results in 'Inaccurate (54). Next track, same situation, second track takes 10 minutes and results with 'Inaccurate (55), then the same thing. The CD I'm importing at the moment is Morcheeba 'The Platinum Collection' and it's about an hour long with 14 tracks. It is 72% way through track 4 and has taken 70 minutes to get that far. First 3 tracks were 54, 55 and 54 Inaccurate. Still going. Takes about 20 to 35 minutes per track. Absolute age.
        Are these errors Inaccurate, as described in your latest post?
        Inaccurate rips can often take a long time to complete and is normal (see your Secure setting options and check the website help pages for more info).
        Please can you be more specific? CD ejects with loads of issues tells us nothing that can help us to help you.
        Copy Protected audio CDs will have a Copy Control logo, somewhere on the artwork/packaging.
        Audio CDs can also have non-visible manufacturing errors.
        Are the successful rips, AccurateRips?
          • 1932
          Did you change the C2 pointer option?
          • MrWriter
            • Nov 2017
            • 35
            After 2-hours on that single CD it took an age to import just the first 5 tracks (About 90 minutes) then it ejected the CD with: Error converting FLAC, 'Track 6' to.....
            So I waited nearly two hours only for it to import just 5 songs before chucking the CD out and giving up.
            • MrWriter
              • Nov 2017
              • 35
              What's that and how do I do it?
                • 1932
                Try to uncheck
                Menu -> CD Ripper Options -> Secure Settings -> C2 Error Pointers for Error Detection
                if it is checked.
                • MrWriter
                  • Nov 2017
                  • 35
                  Try to uncheck
                  if it is checked.
                  Checked those settings and both boxes are unchecked.
                    Can you try and re-rip the Morcheeba - The Platinum Collection CD, with the C2 Error Pointers for Error Detection option ticked and post the outcome?
                    • MrWriter
                      • Nov 2017
                      • 35
                      OUtcome same as before. Takes 25 minutes per track hence about 4 hours for the CD, can't wait that long. Imported first track in 35 minutes with Inaccurate (54), basically the same thing.
                        Try re-ripping a CD which has ripped fine in the past, is it fast or slow at ripping?
                        To me it sounds like your CD drive is broken.
                        • MrWriter
                          • Nov 2017
                          • 35
                          No, I own over 1,000 CDs and I've ripped over 800 of them, all in under 3 minutes each. CD drive is fine.
                            Thats good, but try reripping a CD that previously worked, as a test. Secure ripping puts a lot of stress on drives.
                            • MrWriter
                              • Nov 2017
                              • 35
                              Done that, drive is fine.
