Tags, Tags, and more Tags ...
  • Oggy
    • 697
    Hi Oggy,
    OK, I will stick with what I have just edited for 'The Inner Mountain Flame', and apply it to my remaining Jazz 'THE' albums.
    Paul
    Makes sense, the album's name is, The Inner Mountain Flame.
    • monsterjazzlick
      • 1764
      I was just looking through some of my screenshots (on the previous page) and I think I may have made a mistake regarding ARTIST name (who's name includes a 'THE'). I'll check my FLACs and see if it was just a one-off, or if it runs through all of the respective taggings.
      Cheers.
      • Jailhouse
        • Sep 2016
        • 388
        No, it isn't. You managed to rename The Inner Mounting Flame back in post No. 283.
        • Oggy
          • 697
          Many apologies, so I did.
          • monsterjazzlick
            • 1764
            Hi guys,
            My suspected error is that I named the ARTIST tag for John McLaughlin's outfit as:
            ARTIST = Mahavishnu Orchestra, The
            and ALSO for:
            ARTISTSORT = Mahavishnu Orchestra, The
            And so I wanted to double-check, please, if this type should be tagged as above, OR as:
            ARTIST = The Mahavishnu Orchestra
            Today is the first time I have used an ARTISTSORT tag.
            Much appreciated,
            Paul
            • monsterjazzlick
              • 1764
              Hi again,
              On a 'THE' related note, if the album name already has a comma, by default, then does this make any difference as to whether or not, or how you might compile, the ALBUMSORT tag, please? I am referring to the album:
              ALBUM = 'The Best Of Emerson, Lake & Palmer'
              And so, would you tag this as:
              ALBUMSORT: Best Of Emerson, Lake & Palmer, The
              Thanks very much.
              Paul
              • monsterjazzlick
                • 1764
                When I was in my early teens, and I did not own any Jazz records, I had only heard people mention certain key albums. I actually thought, for a long period of time, that it was called: "In A Mountain Flame"!
                • Jailhouse
                  • Sep 2016
                  • 388
                  Folks in some parts would pronounce the album name as "The Inna Mountin' Flame"....
                  • Jailhouse
                    • Sep 2016
                    • 388
                    ...would you tag this as:
                    I would indeed.
                    • Jailhouse
                      • Sep 2016
                      • 388
                      Hi guys,
                      and ALSO for:
                      The ARTIST tag should read the way you want it displayed; I presume that means, "The Mahavishnu Orchestra". ARTISTSORT should be the way it reads in both the above cases.
                      • Oggy
                        • 697
                        Hi Paul,
                        ARTIST = The Mahavishnu Orchestra. This is the artist name, so makes most sense to use it.
                        ARTISTSORT = Mahavishnu Orchestra, The will "sort" the artist under Ms, which works for a number of people, me included.
                        ALBUMSORT is a strange one, and obviously comes down to what makes sense to you. Here are a couple of examples which show my logic. This may, or may not make sense to you!
                        ARTIST = The Beatles
                        ARTISTSORT = Beatles, The
                        ALBUM = The Beatles
                        I personally do not use ALBUMSORT, which may seem contradictory, but here is my reasoning:
                        ARTIST = Kate Bush (obviously there is a choice of using ARTISTSORT, or not).
                        ALBUM = The Kick Inside
                        In my mind, the album name is The Kick Inside, so I would expect it to fall under Ts, as I would (album name) The Beatles.
                        The library that works best for an individual, is likely to be one where we find what we want instinctively, so purely personal choice based on our own requirements.
                        In the case of The Best Of Emerson, Lake & Palmer, I would also expect this to be in Ts, following and not preceding, Brain Salad Surgery: you may well not.
                        • monsterjazzlick
                          • 1764
                          Hi JH,
                          I would indeed.
                          OK, I will go along with that, thanks.
                          Paul
                          • monsterjazzlick
                            • 1764
                            East Anglia, UK!
                            • monsterjazzlick
                              • 1764
                              Cheers Oggy,
                              I will have a look this evening and make a decision.
                              Paul
                              • monsterjazzlick
                                • 1764
                                ALBUM = The Beatles
                                Hi Oggy,
                                I am going to use the ALBUMSORT tag in the way that Jailhouse suggests, thanks:
                                ALBUM = The Beatles
                                ALBUMSORT = Beatles, The
                                But I don't know if JH uses an ALBUMSORT tag for every single CD in his collection? I intend on using it exclusively for albums who's title have an opening 'THE'. And, therefore, albums without an opening 'THE' (in the title) will consequently not have an ALBUMSORT tag.
                                Cheers,
                                Paul
