Tags, Tags, and more Tags ...
  • monsterjazzlick
    • 1764
    Originally posted by Oggy
    If I had no more music by Eddie Arnold and Roy Acuff, I wouldn't use sort tags.
    Oggy,
    They might pop up again in the future if/when I purchase any more 'C&W' compilation CDs. I am actually looking to bump this genre up a little.
    • monsterjazzlick
      • 1764
      I have finished ripping all of my 'Pop' CDs now (it took 6 weeks). I have a question regarding ARTIST and ARTISTSORT, please.
      I have been adding the word VOCAL (in brackets) after the artist's name (because I like to be able to see which albums/tracks have vocals on them):
      As I have written this after the artist's name, obviously, it shows up on every playback device (which is what you want!). For example:
      ARTIST = Bob Dylan (Vocals)
      But I am really stuck as to what I should write for ARTISTSORT:
      ARTISTSORT = Dylan, Bob (Vocals)
      Dylan, Bob, (Vocals)
      ... ie. with or without the comma ','?
      All of my ARTISTSORTs to date have simply been a juxtaposition of all the names within in the ARTIST field. For example:
      ARTIST = Miles Davis
      ARTISTSORT = Davis, Miles
      But, I am wondering if you can have an ARTISTSORT which does not contain every word/name as the former? For example (as in my case):
      I am guessing the latter would be/function fine, but I really want to check first (because it means me editing about 25 CDs).
      Many thanks in advance,
      Paul
      • Jailhouse
        • Sep 2016
        • 388
        I'm guessing the short form ARTISTSORT (Dylan, Bob) would suffice. Anything else is superfluous.
        I would try editing one or two CDs, preferably from artists with more than one CD in your library. If you like the results, edit the rest of your pop library. If not, fiddle with them until you get what you want, then edit the others if necessary.
        • Oggy
          • 697
          Hi Paul,
          If you wish to keep (Vocal) in the filename then I agree: Dylan, Bob.
          Alternatively, you could keep Genre Pop, for vocals and add Genre Pop Instrument - giving instant lists of with without, whilst keeping Bob Dylan simple.
          • monsterjazzlick
            • 1764
            Thanks Oggy,
            I actually tried out your suggestion initially when I started ripping my 'Populars' GENRE (just after Xmas). Yes, it's a good suggestion but I decided against creating another TAG. There are some 'Classical' CDs I have which include 'Vocal FX' and I wanted to make a distinction here; in this instance I intend to add: (Voice), after the Artist's name. For instance:
            Artist = Steve Reich (Voice)
            Many thanks.
            • monsterjazzlick
              • 1764
              Thanks a lot JH,
              I think it is pretty certain that I am going to go along with this suggestion, thanks.
              Cheers,
              Paul
              • monsterjazzlick
                • 1764
                All of the Artists, in my CD collection, who's title includes the word 'The', have been arranged in the following fashion (eg.):
                ARTIST = 'Mahavishnu Orchestra, The'
                ARTISTSORT = 'Mahavishnu Orchestra, The'
                So that, in the above instance, the above Artist appears, alphabetically, under the letter 'M':
                Having ripped my entire Jazz and Popular Genres, I have found that I have many more Albums, than expected, who's titles begin with the word 'The'. Using advice kindly provided in a separate thread (of last year), I arranged the Artist names as per above; but now I am thinking of also applying the same format to the NAMES of albums.
                For instance, I would like to have John McLaughlin's Mahavishnu Orchestra's album:
                'The Inner Mounting Flame'
                appearing under the letter 'I', please. Can I simply rearrange the Album NAME to:
                'Inner Mounting Flame, The'
                Or do I need to create an ALBUMSORT tag, please?
                Many thanks,
                Paul
                  • 5749
                  You can do either. But I would recommend using ALBUMSORT tag.
                  • monsterjazzlick
                    • 1764
                    Hi Garym,
                    OK, cheers.
                    But what would you type into the ALBUM tag, please?
                    or,
                    (as in the case of the aforementioned John McLaughlin album).
                    Paul
                      • 5749
                      Hi Garym,
                      OK, cheers.
                      or,
                      Paul
                      ALBUM: The inner Mounting Flame
                      • monsterjazzlick
                        • 1764
                        Thanks Garym,
                        So - after adding an ALBUMSORT tag - in Foobar, the ALBUM NAME still displays as follows:
                        Is that correct, please?
                        Thanks a lot.
                        Paul
                          • 5749
                          Thanks Garym,
                          Thanks a lot.
                          Paul
                          Yes. It displays as The... but sorts without the the. That is the entire point of using sort tags.
                          • Oggy
                            • 697
                            Thanks Garym,
                            Thanks a lot.
                            Paul
                            Hi Paul,
                            That is exactly what you have asked it to do. You haven't changed the album name, so it displays as The Inner Mountain Flame, but sorts under Inner.
                            • monsterjazzlick
                              • 1764
                              OK, cheers Garym.
                              I have about 25 x CDs which will need to have an ALBUMSORT tag added. Luckily it's only a very quick job!
                              I still have not started ripping my Classical yet, though (as I have saved that Genre til last!).
                              Paul
                              • monsterjazzlick
                                • 1764
                                Hi Oggy,
                                OK, I will stick with what I have just edited for 'The Inner Mountain Flame', and apply it to my remaining Jazz 'THE' albums.
                                Paul
