Meta Data not working on Reference 15.8 or updated Reference 16.1
  • JoelB
    • Feb 2016
    Haven't ripped anything for a few months. Decided it was time to add to my server so I updated from 15.8 to 16.1 (both Reference).
    Meta Data did not work on either
    Decided to try the Trial version of 16.1-
    Meta Data works but no cover art. Not a big deal,I download from a file
    If I rip on the trial version,I of course will get an error trying to accuerip -If I allow the disk to close and eject and THEN place disc back into disc drive it will now load up on 16.1 reference with the meta data-a strange work around :-))
    I did update to OSX El Capitan 10.11.6
    I did register dbpoweramo on my firewall and checked "allow access"
    I did delete the download from documents AND Applications and reloaded
    Tired of doing a "pre-load"
    Help
    Re: Meta Data not working on Reference 15.8 or updated Reference 16.1
    Try removing your firewall software, not just disable, this will show for sure if it is blocking access (also any other security software).
