    Sorting under "J" is incorrect, as "Jo" is not part of Spears' surname. This artist should be in either the B section or the S section.
    Incorrect, according to who? Who states the artist should be in the B section or S section?
    Although I would personally sort artist Billie Jo Spears under S and would advise this, users are able to put what they want in the artist sort tag, so I have to disagree. It is not question of right and wrong here, but of personal choice.
      • 6188
      #287
      Gary, So should I just leave it as it is? You are probably going to say it's all about "options!" I mean, if I did want to include them then do I just TICK the appropriate boxes in the "Meta Data ID Tag" window (as per screenshot 2 above)? And, assuming they will then automatically appear in the "Meta Data for all Tracks" window (as per screenshot 1 above), what data would you fill in, please? Just the Artists name for both fields?: "Davis, Miles". Thanks.
      Yes, tick those items in Meta Data ID Tag, but I suspect they rarely automatically populate when ripping. You need to manually enter the value you want in the sort tags.
      • monsterjazzlick
        • 1764
        #288
        Hi, Can I lose: 'Period' and 'Soloists', please? I guess they are mainly for Classical? I can certainly live without either of them:
        Not sure what: ' Custom' is though?:
          • 6188
          #289
          [ATTACH=CONFIG]1507[/ATTACH]
          [ATTACH=CONFIG]1508[/ATTACH]
          I don't use Period or Soloists. Then again, I have very little classical. Custom is a custom tag that you've created (I assume)....don't use that either.
          • monsterjazzlick
            • 1764
            #290
            There are some tags that have a corresponding sort tag, the most common being:
            Title and Title Sort
            Album and Album Sort
            Artist and Artist Sort
            Album Artist and Album Artist Sort
            Composer and Composer Sort
            Conductor and Conductor Sort
            Soloists and Soloists Sort
            If you choose to populate the sort tags (and I do, except Title) then:
            If Artist = Miles Davis then Artist Sort = Davis, Miles
            If Album Artist = Miles Davis then Album Artist Sort = Davis, Miles
            Hi Mville, I will be using both 'Artist Sort' and 'Album Artist Sort', thanks:
            But do you use 'Album Sort', please? Is it for when you have titles like: 'The Best Of The Bee Gees' or 'The Complete Beatles Collection'; which are to be tagged as: 'Bee Gees, The Best Of' and 'Beatles Collection, The Complete'?
            However, I am not sure if I would use the latter mentioned because I think I have enough data to try to remember each time I perform a rip!
            • monsterjazzlick
              • 1764
              #291
              Hi Gary, Well I created 'Producer', 'Recorded', and 'Label' - so I guess these fall under 'Custom'?:
              • monsterjazzlick
                • 1764
                #292
                Hi again,
                Some other tag-boxes which are all checked:
                Is 'Length' the total-duration of he CD, please? I would have thought that an mp3-player would automatically read this from the disc? Or maybe this field is provided so as to enabling the user to run a search by album-length?:
                And hare are the remainder of tag-boxes which are all unchecked:
                Hopefully these are all correct.
                Thanks!
                • Oggy
                  • 703
                  #293
                  [ATTACH=CONFIG]1509[/ATTACH]
                  I may be being radical here, but I name, The Best Of The Bee Gees, The Best Of The Bee Gees.
                    • 6188
                    #294
                    Hi again,
                    Thanks!
                    there is no correct or incorrect. It's whatever tags you want to use, in whatever way you want to use them. I can see you have the idea of how to select or deselect tag fields, so just use the ones you want that fit your needs.
                      • 6188
                      #295
                      I agree. At some point use of sort tags where not really needed becomes rather silly.
                      • Jailhouse
                        • Sep 2016
                        • 388
                        #296
                        It's wrong if one intends to sort either by first name or last name. (Of course, this assumes that in the example, "Jo" is a middle name or part of a full first name.)
                        If anybody actually wants to sort by middle name, I'm not going to argue.
                        • Jailhouse
                          • Sep 2016
                          • 388
                          #297
                          Totally agree with this.
                          One of the few exceptions I've seen in music libraries, is, Ralph Vaughan Williams.
                          There is no hyphen, but:
                          Sorting under surname, then, V = Vaughan Williams, Ralph
                          Sorting under Christian name, then, R = Ralph Vaughan Williams
                          I didn't use Artist Sort in the above, because some would use Composer, and Composer Sort.
                          Classical tagging, in the absence of accepted standards, is even more open to personal preferences.
                          I wouldn't consider that to be an exception, as "Vaughan Williams" is the composer's surname.
                          • monsterjazzlick
                            • 1764
                            #298
                            Thanks Gary, I will stick with what I have got so far I think. Which is quite a few to be going on with!
                            But if you could confirm the definition/function of 'Length' (as per [above] screenshot 'Tag_7'), please, that would be great? Paul
                            • monsterjazzlick
                              • 1764
                              #299
                              Am dreading the time I get around to ripping my 'Classicals'! Paul
                                • 6188
                                #300
                                Yes. Length tag is just storing that info. Can't hurt. I store it, but have never actually used it for anything. You are correct that most players will know that info from the actual track whether you store in tag or not.
