Play Sound After Conversion Causing Crashes
  • southpawBK
    • Jun 2017
    I'm having an issue where DSP Play Sound After Conversion seems to be causing an error message to pop up every time it's used. The scenario is that I rip a cd, the sound is played, and then a message is displayed that "DBpoweramp Music Converter quit unexpectedly". The thing is that DBpoweramp is not actually quitting and I can close the error message and continue using the app. Still I would love for this not to happen. Any help would be greatly appreciated.
    Re: Play Sound After Conversion Causing Crashes
    If you remove the DSP effect it does not show that message?
    Do you hear any sound with the effect? have you tried selecting a different audio file to play?
    • southpawBK
      • Jun 2017
      Yes, if I remove the DSP I do not get an error message.
      The chosen sound for the DSP does play before the error message and chosing a different sound had no effect. They were even in different locations on the drive and one was a WAV, the other was an AIFF.
      And just to add more info, I'm using DBpoweramp v16.1 on a Mac running OS 10.12.4
