my cd ripper does not work
  • gar_charles
    • Oct 2016
    • 8
    Good day , just bought db power amp and it does not work. Tried uninstalling then reinstalling it and still no joy. Trial version was working fine. Using pc with wondows 10.
    • 46160
    Re: my cd ripper does not work
    In what way does it not work? Which part does not work?
    • gar_charles
      • Oct 2016
      • 8
      The window does not open, cannot access metadata impossible to use at all
      • gar_charles
        • Oct 2016
        • 8
        the software does not recognise any discs in my drive
        • gar_charles
          • Oct 2016
          • 8
          i cannot seem to be able to contact the seller, at this point I want my money back as the software is completely useless to me
            Are you able to play CDs in this drive, using any other software?
            • gar_charles
              • Oct 2016
              • 8
              yes, itunes poses no problem, am able to rip music to itunes library, and before purchasing, was able to use trial version impeccably
                • 1914
                What security software are you using?
                • marcaurel
                  • May 2007
                  • 24
                  maybe it's the same problem that happened to me. after updating windows 10, cd ripper didn't recognize any drives.
                  Solution was to start cd ripper as admin.
                  Does anyone know why this is so? Is there any other solution than starting as admin?
                    • 46160
                    It will be security software related, Windows (normally) does not need CD Ripper to run as admin.
                    • gar_charles
                      • Oct 2016
                      • 8
                      Hi there , can you please explain to me how to do what you just described?
                      • marcaurel
                        • May 2007
                        • 24
                        - right click on CD Ripper
                        - run as Administrator
                        • gar_charles
                          • Oct 2016
                          • 8
                          i set db power amp and cd ripperas admin and still does not work, cannot even maximise the miniature window in which it opens
                            • 46160
                            Refunded as requested.
                            • gar_charles
                              • Oct 2016
                              • 8
                              Too bad, I really want and NEED this program, I would have much preferred to have had support/help to make it work properly. I had stated this in my message to you via paypal, but I got no reply, just money back which does not really help. :-(
