CD Ripper missing first track of a CD
  • Wildlife7739
    • Mar 2026
    I've been using CD Ripper on and off for about 20 years and stumbled across some new today.
    I tried ripping a brand new CD just unwrapped and the first track is missing in CD Ripper. It only displays tracks 2 through 21. I verified that track 2 is the correct track 2 and track 21 is the correct track 21. Track 1 is completely missing.
    I can open the CD in VLC (Computer > Optical drive > Right-click > Play with VLC) and see and play track 1 and the rest of the album.
    After ripping this CD (sans track 1) I then ripped 2 other new CDs without issue. All CDs are from the same band, and one of them was part of a multi-album pack that included the CD missing track 1.
    Windows 11 25H2
    dBpoweramp Release 2026-01-31, installed to C: drive, and I rip to D:
    DIY desktop PC w/ 9800x3D, 32GM RAM
    TSST SE-208GB USB CD/DVD drive that I've had for probably 7 years without issue.
    Switch ripping method for that one disc to 'Defective by Design'
    • Wildlife7739
      • Mar 2026
      Thanks, that did it!
      • lanky
        • Apr 2026
        1. I have installed CDripper several months ago on my WIN10 pro Toshiba laptop with intern CD-drive and all works fine. In the last 2 weeks I ripped ca. 300 CDs and since a few days it ripps nothing more, every file is quit with an error on several CDs. The same by using another extern CD-drive.
        2. updating updates 2026 is not possible
          What is the exact error message?
          • lanky
            • Apr 2026
            error reading db command file
              That means something (likely security software) is blocking dBpoweramp, or your %tmp% drive is full.
              • lanky
                • Apr 2026
                so what can I do?
                  Check your all your drives have free space, atleast 10GB on the system drive.
                  If still no go as a test restart in safemode, no security software is running, try ripping a CD:
                  • lanky
                    • Apr 2026
                    OK. HHD-space was to weak, only 86 MB left. What a stupid question. thx + nice eastern
