Will current release of CD Ripper/PerfectTunes work with outdated OS X?
  • joeyc410
    • Jun 2019
    • 46
    Hello,
    I’m in a debacle as my ripping PC appears to have died. I am researching buying a portable CD drive for my iMac but the problem is, my iMac is old and hasn’t been able to be updated to the latest OS since 2019. I see the current version of CD Ripper and PerfectTunes is stated to work with OS X Big Sur (released 2020) or newer. My question is - if I purchased this latest version on my older iMac, would it simply not work? Or would it run but with the recommendation that I sooner than later get a newer computer? If there is no way for the software to work on my old iMac, I’m basically unable to rip CDs until I spend $2000+ on a new machine, and I’d prefer to wait on that until a bit later.
    Thank you.
  • joeyc410
    • Jun 2019
    • 46
    To add, I am consulting the community about whether or not it would be a good idea to buy this drive. It’s a simple choice, I know, but I think it’ll do what I need it to do.
      Once acquire a registration, you can download the last version supported by the OS.
      • joeyc410
        • Jun 2019
        • 46
        Thank you. I am assuming the old version I purchased for Windows cannot be installed on a Mac, even if I have a license already? In 2019, I remember there being a version of CD Ripper for Windows and a version for Mac, but now it is jointly compatible?
          Yes you would have bought the Windows version which was licensed separately back then
          • Eric_QelDroma
            • Aug 2006
            I'm in almost exactly the same boat* in that I bought a license for Windows in 2019 and cannot seem to download a Mac version today. Do I need to purchase a new license that will (I assume) be Windows/Mac compatible?
            (To be clear, I've used dbPowerAmp so much over the last seven years that I don't consider it a great hardship to pay again. I absolutely love the program and have gotten my money's worth even if I never use it another day.)
            *I've switched away from Windows and am using Linux for 90% of my work. However, I also own a Mac Mini where I do much of my music archiving.
              Correct, Windows and macOS were combined as of R202x versions
