Metadata retrieval problem in ver. 2025-11-12
  • Ninja50
    • Oct 2022
    In earlier versions of dBpoweramp I was able to uncheck all the Active Provider metadata sources to rip a disc with a clean slate for metadata. If I do the same in 2025-11-12 it still populates the fields with metadata suggestions.
    I'm also in the process of re-ripping some of my discs. For one particular disc I loaded up, dBpoweramp listed the "Track 1", "Track 2", ... names & track times for the disc, but gets stuck "Retrieving CD Metadata." I can't cancel out of that step. Again, unchecking all the Active Provider metadata sources doesn't stop it from trying to fetch that info. I'm using the same unscratched disc, drive, & computer I used to successfully rip it last month. The only thing that has changed is the version of dBpoweramp and the fact that I can't skip downloading the metadata for rather obscure disc this time. Foobar plays the disc without problem. I realize this doesn't give you much info to work with, but are the two metadata problems related?
    Enable one provider, and use the DSP effect 'ID Tag Processing' to delete all metadata.
    • Ninja50
      • Oct 2022
      Thanks, I had totally forgotten about that DSP effect.
