FLAC rip in dBpoweramp vs Foobar2000
  • crucifyd
    • Apr 2013
    • 24
    Out of curiosity I ripped a CD in dBpoweramp and then the same CD in Foobar2000 (both set at compression level 0).
    dBpoweramp rip file size: about 385MB
    Foobar rip file size: about 285MB
    At first dBpoweramp had FLAC 1.3.1 and Foobar had FLAC 1.2.1. I thought that might be why the variation. I switched up Foobar so it is now using FLAC 1.3.1 and tried again. Same result.
    It seems no matter what you rip, image or tracks they all come out smaller when using Foobar.
    Not really a big deal. Just curiosity is all. My logic (!) says if you are using the same version of FLAC, it shouldn't matter what ripper you use.
    1. Does anyone know why there would be a difference in file size?
    2. Whatever the reason, I assume it makes no difference to the perfect copy of the CD, correct?
  • eaglescout1998
    • Apr 2009
    • 203
    Re: FLAC rip in dBpoweramp vs Foobar2000
    Perhaps dBpoweramp is embedding album art? That would account for the larger file size.
    • crucifyd
      • Apr 2013
      • 24
      It is about 100 MB difference...seems like a lot for album art to me...and I have everything set up not to include it anyway.
      I also tried making a FLAC in Foobar from the original FLAC ripped in dB and I got the same result.
      No matter what I try in Foobar, either "convert" from the original dB rip or rip it directly from the CD in Foobar, it is always about 100 MB smaller than the dB version...
        dBpoweramp version is 16 bits?
        • crucifyd
          • Apr 2013
          • 24
          well, I downloaded it after entering my order number @ https://secure.dbpoweramp.com/getorder.aspx
          Is there a way to check for sure?
          Is there a way to make sure dB and all the codecs etc. installed are 64-bit?
            Sorry I meant the flac files are 16 bit? for both
