Please Help! VBR, ABR, CBR, and Free Format (Coverting CD to MP3)
  • xxdaanimalxx
    Hi everyone, I DJ and prefer 320kbps...
    In the VBR section it only goes up to 240kbps
    I know VBR is more used to be convert music... but
    Which one of these is safe to use so I can use my files on any windows or mac
    program when I dj...? I see free format and it always me to put 320kps... but when I put 320kbps
    it says check player for compatibility in ( )'s and goes way past 600...
    what is the safe route to ensure me i can use these files at 320kbps in windows and mac and any dj program when i entertain?
    Can VBR be at 320kbps if possible....?
    Also, I ripped a cd to test the program out, but what does the rip status means...?
    I have mostly all accurate 7's and the last track as accurate 3....?
    Finally, how can I speed up my CD ripping to 24x where is that option? Thank you!!!
  • dbfan
    • Jan 2011
    • 937
    Re: Please Help! VBR, ABR, CBR, and Free Format (Coverting CD to MP3)
    Do not use free format is you want the files to play in everything.
    For best quality use CBR 320 kbps, standard mp3 files cannot get any better quality than that.
    CD Ripping happens at the maximum speed the drive allows, if it is ripping at x10, then that is all the drive is able to do.
    See:
    Under the title 'Rip Status'
    • xxdaanimalxx
      • dbfan
        • Jan 2011
        • 937
        If the tracks are accurate, then they are verified as being error free using the accurate rip database.
          • 6186
          and the "3" vs "7" vs even "200" doesn't mean it is more or less accurate, any AR match is good (unless you ripped the same CD yourself in the past and it was recorded in the AR database...in this case you are comparing to yourself if AR=1).
          • xxdaanimalxx
            Image include, 16 tracks, but out of 16 tracks, 15 say accurate........... Click image for larger version
ID:	292900 My track 14 skipped, so I went to buy another new cd rom.... now as I put it back in, these are the results I get...... I cleaned my cd with a cd-r skipper machine.......
            • xxdaanimalxx
              I did record it in the past, but shouldn't it show "updated results" now that I both especially a new cd rom..... and i cleaned the disc using a product..? Image is included below in this thread for you all too see, further help for me to comprehend would be appreciated, this is all new to me
                • 6186
                I'm confused by your question. You ripped a CD and one item wasn't matched in AR. Did it report SECURE or WARNING or ERROR? When you played this track it skipped? Does it skip when playing the original CD or just on your rip of track 14? Have you tried ripping the CD on a different computer or different drive? That can sometimes give you a good rip. I'm not sure what CD-R has to do with anything. Is this CD you are ripping a commercial CD or is it a CD-R? Although that shouldn't make any difference. You can rip either.
