Bug? Exact Audio Copy works where dbpoweramp doesn't?
  • jensk74
    • Jun 2014
    • 10
    Re: Bug? Exact Audio Copy works where dbpoweramp doesn't?
    Thanks for the link.
    For what it's worth, I found a "LowerFilters" entry in the registry for the optical drives. It seems to be linked to "INTEL Rapid Storage Technology" software I have installed.
    http://www.intel.com/support/chipset.../CS-020784.htm
    The system is INTEL based (CPU and most chipsets) and I remember having all kinds of horrible problems when I first set it up and decided not to install that software because I did not think that I needed the features (something to do with SSD caching and RAID I think). So uninstalling will probably lead to even more trouble.
    I will try installing a newer version of the software instead. I also wonder what just deleting that filter driver registry entry for the optical drives will do. Does Windows automatically use its own native drivers then?
      • 46198
      The intel drivers should not be used for CD Rom...
      Filters are not drivers, they are code which everything CDROM passes through.
