No audio data after a rip
  • Fleetway
    • Apr 2014
    • 15
    Re: No audio data after a rip
    Yes, that's right. I either get Accurate (2) or Accurate (15). All the metadata is visible for the track, viz.:
    • Fleetway
      • Apr 2014
      • 15
      Has there been any progress on identifying what is happening here?
        • 46027
        No, I have never seen anything like it before.
        All we know is that data is leaving CD Ripper correctly ( as has accuraterip verification )
        however it is not being written to the final file.
        Try setting the encoder as [Calculate Audio CRC], the CRC should match the CRC shown in CD Ripper (under the CRC column). If it does then it is reaching the final part of the program correctly (CoreConverter).
        If you do not have this codec, it is in the utility section of Codec Central.
        • Fleetway
          • Apr 2014
          • 15
          I gave Calculate Audio CRC a spin as you suggested, instructing the encoder to use CRC32. I ripped two tracks on a CD and this is what popped up. The number by "CRC32" on Line 4 of each track information paragraph is the same as is listed in the CRC column of the main CD Ripper window. This time the final result given was Accurate (27).
          Information ripping to [Calculate Audio CRC], 'Track 1' to 'C:\Users\Rob\Music\Milli Vanilli\All or Nothing; The U.S. Remix Album\01 Milli Vanilli - Blame It On The Rain (Super Club Mix).IGNORE'
          Track 1: Ripped LBA 32 to 30282 (6:43) in 1:02. Filename: C:\Users\Rob\Music\Milli Vanilli\All or Nothing; The U.S. Remix Album\01 Milli Vanilli - Blame It On The Rain (Super Club Mix).IGNORE
          AccurateRip: Accurate (confidence 27) [Pass 1]
          CRC32: 41055767 AccurateRip CRC: B95B599B (CRCv2) [DiscID: 009-000eb9e6-006afd24-770a4309-1]
          AccurateRip Verified Confidence 27 [CRCv2 b95b599b]
          AccurateRip Verified Confidence 47 [CRCv1 afcc24eb]
          AccurateRip Verified Confidence 2 [CRCv2 fea333bb], Using Pressing Offset +539
          AccurateRip Verified Confidence 6 [CRCv1 ce08fec1], Using Pressing Offset +539
          Information ripping to [Calculate Audio CRC], 'Track 2' to 'C:\Users\Rob\Music\Milli Vanilli\All or Nothing; The U.S. Remix Album\02 Milli Vanilli - More Than You'll Ever Know.IGNORE'
          Track 2: Ripped LBA 30282 to 47770 (3:53) in 0:30. Filename: C:\Users\Rob\Music\Milli Vanilli\All or Nothing; The U.S. Remix Album\02 Milli Vanilli - More Than You'll Ever Know.IGNORE
          CRC32: DD723A64 AccurateRip CRC: EA813516 (CRCv2) [DiscID: 009-000eb9e6-006afd24-770a4309-2]
          AccurateRip Verified Confidence 27 [CRCv2 ea813516]
          AccurateRip Verified Confidence 46 [CRCv1 ed5bc96]
          AccurateRip Verified Confidence 2 [CRCv2 9d1926bd], Using Pressing Offset +539
          AccurateRip Verified Confidence 7 [CRCv1 85ea837c], Using Pressing Offset +539
          In addition to the above, after finishing a rip a text window is opened with filename "dbp7AC.tmp". These list the CRCs of both tracks as a string of zeroes. This is the only text in the file:
          CRC32 Filename
          00000000 -
          00000000 -
          I tried ripping the same two files again with the MD5 and AccurateCRC boxes also ticked on the encoder settings, and this text box came up, filename "dbp93FD.tmp":
          CRC32 MD5 Filename
          00000000 D98C1DD404B2008F980980E97E42F8EC -
            • 46027
            >CRC32 Filename
            >00000000 -
            >00000000 -
            Something on your system is stopping the piping of data from CD Ripper to Core Converter. Perhaps a security setting, I am not sure as I have not seen anything like it before. A CRC of 0 means no data is recieved by CoreConverter.
