No audio data after a rip
  • Fleetway
    • Apr 2014
    • 15
    I am a registered user of dbPoweramp. I have version R15 installed.
    A fault has developed with the CD Ripper. Normally a progress bar showing the percentage of track ripped appears, but I have noticed that recently this has changed - "Ripping 0%" will blink for a split-second and then change immediately to "*tick* Complete". This will hold for a few seconds before changing to "Accurate (2)". The ripped tracks appear in my destination folder as .flac files, and include all metadata, but there is no audio data, and the track lengths are 0. Following the advice of this support thread I right-click and "Run as Administrator" for the CD Ripper, but I have successfully ripped CDs as normal this way before so I am not sure if it is responsible. I have not changed any other options or preferences in the CD Ripper so I am honestly baffled as to why this has started happening. Any assistance would be appreciated.
    • 46143
    Re: No audio data after a rip
    How long does it take to rip the whole CD?
    • Fleetway
      • Apr 2014
      • 15
      Thanks for your response - an extended period without internet prevented me from following-up on this problem, but I am afraid that it still continues so I still need help. A complete CD of 20+ music tracks currently finishes ripping in about 3 to 4 minutes.
      I've tried ripping a CD again now - it has the same issue, except when finished the tracks gave a different status from before, "Accurate (15)" instead of (2).
        • 46143
        The numbers all seem right. Try this:
        Close CD Ripper
        Start dBpoweramp Configuration >> Music Converter
        enable the debug option. Click Ok.
        Start CD Ripper and rip 1 track only to FLAC, then close CD Ripper, the debug log will show in Notepad on close, copy the text and paste here please.
        • Fleetway
          • Apr 2014
          • 15
          Two logs.
          1) This one came up automatically on ripping a single track:
          ===================================START LOG========================================
          Splitting Command Line:Done
          ->-> [dBCoreConverter::ReaddBCommandFile]
          <-<- [dBCoreConverter::ReaddBCommandFile]
          Allying to Processor 1
          ->-> [cldBCodecHandler::LoadEncoder]
          Loading Encoder 'C:\Program Files\dBpoweramp\encoder\FLAC.DLL'
          <-<- [cldBCodecHandler::LoadEncoder]
          BatchID [clEncoder::Set]
          ->-> [dBCoreConverter::StripCoreConverterCmds]
          <-<- [dBCoreConverter::StripCoreConverterCmds]
          SendRawUnCompressed [clEncoder::Get]
          Communicate [clEncoder::Get]
          ->-> [dBCoreConverter::OpenDecoder]
          Reading StdIn Tmp File IDTags: Read
          Using StdInput WFX:Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
          <-<- [dBCoreConverter::OpenDecoder]
          SendOverReplayGainTags [clEncoder::Get]
          ->-> [clEncoder::BeginConversion]
          Converting to 'C:\Users\Rob\Music\Hans Zimmer\Rush\01 Hans Zimmer - 1976.flac.tmp.flac' encoder settings ' -compression-level-5'
          FLAC Compression Level: 5
          <-<- [clEncoder::BeginConversion]
          Encoding To: FLAC
          Encoder Cmd Line: -compression-level-5
          ->-> [dBCoreConverter::CloseDecoder]
          <-<- [dBCoreConverter::CloseDecoder]
          ->-> [clEncoder::EndConversion]
          <-<- [clEncoder::EndConversion]
          File Size Check (before overwrite final): 14754 bytes Filename: C:\Users\Rob\Music\Hans Zimmer\Rush\01 Hans Zimmer - 1976.flac.tmp.flac
          File Size Check (before ID Tags Written): 14754 bytes Filename: C:\Users\Rob\Music\Hans Zimmer\Rush\01 Hans Zimmer - 1976.flac
          ->-> [dBCoreConverter::IDTagWriter]
          Decodes [clDecoder::Get]
          IDTags [clDecoder::Set]
          ->-> [clDecoder::WriteIDTags]
          Opening file 'C:\Users\Rob\Music\Hans Zimmer\Rush\01 Hans Zimmer - 1976.flac' for write access: Opened
          ->-> [clDecoder::Open]
          Opening file 'C:\Users\Rob\Music\Hans Zimmer\Rush\01 Hans Zimmer - 1976.flac' for read access: Opened
          Init FLAC:
          Reading Meta Data:
          contained 0 tags:
          ->-> [clDecoder::ReadIDTags]
          <-<- [clDecoder::ReadIDTags]
          <-<- [clDecoder::Open]
          ->-> [clDecoder::Close]
          <-<- [clDecoder::Close]
          <-<- [clDecoder::WriteIDTags]
          <-<- [dBCoreConverter::IDTagWriter]
          ===================================END LOG========================================
          2) This one came up when I closed the CD Ripper
          Using SCSI PassThrough [clCDDA::SetCommunication]
          ->-> [frmMain::RefreshTrackListing]
          Quitting Meta Thread: Quit
          ->-> [clCDDA::ReturnDriveList]
          Got drive C:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
          Got drive D:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
          Got drive E:\ CD ROM [cddaSCSIPassTru::FillDriveList]
          Got drive F:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
          Got drive G:\ CD ROM [cddaSCSIPassTru::FillDriveList]
          Got drive H:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
          Got drive J:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
          <-<- [clCDDA::ReturnDriveList]
          ->-> [clCDDA::ReadTOC]
          LBA FirstIndex: 1 last Index: 24
          Type: Audio Track 1 LBA Address: 0 Length: 00:03:00.066
          Type: Audio Track 2 LBA Address: 13505 Length: 00:00:44.840
          Type: Audio Track 3 LBA Address: 16868 Length: 00:02:47.787
          Type: Audio Track 4 LBA Address: 29452 Length: 00:01:29.693
          Type: Audio Track 5 LBA Address: 36179 Length: 00:03:15.374
          Type: Audio Track 6 LBA Address: 50832 Length: 00:01:28.040
          Type: Audio Track 7 LBA Address: 57435 Length: 00:00:53.720
          Type: Audio Track 8 LBA Address: 61464 Length: 00:02:52.453
          Type: Audio Track 9 LBA Address: 74398 Length: 00:01:05.400
          Type: Audio Track 10 LBA Address: 79303 Length: 00:01:01.573
          Type: Audio Track 11 LBA Address: 83921 Length: 00:02:56.680
          Type: Audio Track 12 LBA Address: 97172 Length: 00:01:49.587
          Type: Audio Track 13 LBA Address: 105391 Length: 00:00:36.093
          Type: Audio Track 14 LBA Address: 108098 Length: 00:05:09.000
          Type: Audio Track 15 LBA Address: 131273 Length: 00:02:39.720
          Type: Audio Track 16 LBA Address: 143252 Length: 00:01:14.880
          Type: Audio Track 17 LBA Address: 148868 Length: 00:05:33.960
          Type: Audio Track 18 LBA Address: 173915 Length: 00:03:30.520
          Type: Audio Track 19 LBA Address: 189704 Length: 00:03:45.094
          Type: Audio Track 20 LBA Address: 206586 Length: 00:02:48.840
          Type: Audio Track 21 LBA Address: 219249 Length: 00:03:07.346
          Type: Audio Track 22 LBA Address: 233300 Length: 00:04:11.800
          Type: Audio Track 23 LBA Address: 252185 Length: 00:06:19.667
          Type: Audio Track 24 LBA Address: 280660 Length: 00:02:33.960
          Type: Lead Out LBA Address: 292207
          MSF FirstIndex: 1 last Index: 24
          Type: Audio Track 1 MSF: 0/2/0 Length: 00:03:00.066
          Type: Audio Track 2 MSF: 3/2/5 Length: 00:00:44.840
          Type: Audio Track 3 MSF: 3/46/68 Length: 00:02:47.787
          Type: Audio Track 4 MSF: 6/34/52 Length: 00:01:29.693
          Type: Audio Track 5 MSF: 8/4/29 Length: 00:03:15.374
          Type: Audio Track 6 MSF: 11/19/57 Length: 00:01:28.040
          Type: Audio Track 7 MSF: 12/47/60 Length: 00:00:53.720
          Type: Audio Track 8 MSF: 13/41/39 Length: 00:02:52.453
          Type: Audio Track 9 MSF: 16/33/73 Length: 00:01:05.400
          Type: Audio Track 10 MSF: 17/39/28 Length: 00:01:01.573
          Type: Audio Track 11 MSF: 18/40/71 Length: 00:02:56.680
          Type: Audio Track 12 MSF: 21/37/47 Length: 00:01:49.587
          Type: Audio Track 13 MSF: 23/27/16 Length: 00:00:36.093
          Type: Audio Track 14 MSF: 24/3/23 Length: 00:05:09.000
          Type: Audio Track 15 MSF: 29/12/23 Length: 00:02:39.720
          Type: Audio Track 16 MSF: 31/52/2 Length: 00:01:14.880
          Type: Audio Track 17 MSF: 33/6/68 Length: 00:05:33.960
          Type: Audio Track 18 MSF: 38/40/65 Length: 00:03:30.520
          Type: Audio Track 19 MSF: 42/11/29 Length: 00:03:45.094
          Type: Audio Track 20 MSF: 45/56/36 Length: 00:02:48.840
          Type: Audio Track 21 MSF: 48/45/24 Length: 00:03:07.346
          Type: Audio Track 22 MSF: 51/52/50 Length: 00:04:11.800
          Type: Audio Track 23 MSF: 56/4/35 Length: 00:06:19.667
          Type: Audio Track 24 MSF: 62/24/10 Length: 00:02:33.960
          Type: Lead Out MSF: 64/58/7
          <-<- [clCDDA::ReadTOC]
          ->-> [frmMain::GetMeta]
          ->-> [clMetaData::GetMetaData]
          ->-> [clMetadBCache::GetMetaData]
          <-<- [clMetadBCache::GetMetaData]
          <-<- [clMetaData::GetMetaData]
          ->-> [frmMain::MetaDataGot]
          Meta Final Pass
          <-<- [frmMain::MetaDataGot]
          <-<- [frmMain::GetMeta]
          <-<- [frmMain::RefreshTrackListing]
          dBpoweramp Release 15 Digital Audio Extraction Log from 06 May 2014 19:39
          Drive & Settings
          Ripping with drive 'E: [TSSTcorp - DVDWBD SN-406AB ]', Drive offset: 6, Overread Lead-in/out: No
          AccurateRip: Active, Using C2: No, Cache: None, FUA Cache Invalidate: No
          Encoder: FLAC -compression-level-5
          Extraction Log
          Ripping Method: Burst
          ->-> [clRipperBurst::Init]
          ->-> [clCDDA::SetDriveSpeed]
          <-<- [clCDDA::SetDriveSpeed]
          <-<- [clRipperBurst::Init]
          ->-> [clCDDA::Destroy]
          <-<- [clCDDA::Destroy]
          ->-> [clCPUEncoder::WriteAccRipCRCTags]
          Init FLAC:
          Reading Meta Data:
          contained 16 tags:
          Title: 1976
          Year: 2013 09 09
          Composer: Hans Zimmer
          Label: WaterTower Music
          UPC: 794043172267
          Style: Soundtracks
          Original Score
          Album: Rush
          Genre: Stage & Screen
          Artist: Hans Zimmer
          Source: CD (Lossless)
          Encoded By: dBpoweramp Release 15
          Encoder: (FLAC 1.3.0)
          Encoder Settings: -compression-level-5
          Track: 1/24
          Disc: 1/1
          Album Artist: Hans Zimmer
          Contains picture block, size (bytes): 12221 type: 3
          <-<- [clCPUEncoder::WriteAccRipCRCTags]
          1 Tracks Ripped Accurately
          ->-> [clMetaData::SaveMetaData]
          ->-> [clMetadBCache::SaveMetaData]
          <-<- [clMetadBCache::SaveMetaData]
          <-<- [clMetaData::SaveMetaData]
            • 46143
            As a test change the encoder to Wave, rip one track and see if the audio length is zero also.
            • Fleetway
              • Apr 2014
              • 15
              The audio length remained 0:00 for the wave version as well. The file size is 12.7kB.
              Logs:
              Loading Encoder 'C:\Program Files\dBpoweramp\encoder\Wave.DLL'
              Converting to 'C:\Users\Rob\Music\Hans Zimmer\Rush\01 Hans Zimmer - 1976.wav.tmp.wav' encoder settings ' -compression="PCM"'
              Wave output WaveFormat: Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
              ->-> [clRIFFHandler::InitializeNewWAV]
              clRIFFHandler::CalcAllChunks: Ok
              ->-> Adding Chunk 'fmt ' Length: 16 [clRIFFHandler::AddChunk]
              <-<- [clRIFFHandler::AddChunk]
              ->-> Adding Chunk 'data' Length: 0 [clRIFFHandler::AddChunk]
              ->-> [clRIFFHandler::WriteChunkHeaders]
              Writing Chunk Header 'fmt ' Length: 16 ChunkPosition: 12 ChunkDataPos: 20
              Writing Chunk Header 'data' Length: 0 ChunkPosition: 36 ChunkDataPos: 44
              <-<- Exit as only write to data chunk [clRIFFHandler::WriteChunkHeaders]
              Writing Chunk Data 'fmt ' Length: 16 ChunkPosition: 12 ChunkDataPos: 20
              <-<- [clRIFFHandler::InitializeNewWAV]
              Encoding To: Wave
              Encoder Cmd Line: -compression="PCM"
              <-<- [clRIFFHandler::WriteChunkHeaders]
              File Size Check (before overwrite final): 44 bytes Filename: C:\Users\Rob\Music\Hans Zimmer\Rush\01 Hans Zimmer - 1976.wav.tmp.wav
              File Size Check (before ID Tags Written): 44 bytes Filename: C:\Users\Rob\Music\Hans Zimmer\Rush\01 Hans Zimmer - 1976.wav
              ->-> [clWaveDecoder::WriteIDTags]
              ->-> [clRIFFBEXTChunk::TagsToBEXT]
              Encoding BEXT chunk [clRIFFBEXTChunk::TagsToBEXT]
              <-<- [clRIFFBEXTChunk::TagsToBEXT]
              Opening file 'C:\Users\Rob\Music\Hans Zimmer\Rush\01 Hans Zimmer - 1976.wav' for write access: Opened
              ->-> [clRIFFHandler::Initialize]
              <-<- [clRIFFHandler::Initialize]
              ->-> [clRIFFHandler::ScanFile]
              RIFF Header 'RIFF' Length: 36 FormType 'WAVE'
              Got Chunk 'fmt ' Length: 16 RiffSizeLeft: 24 ChunkPosition: 12
              Got Chunk 'data' Length: 0 RiffSizeLeft: 0 ChunkPosition: 36
              <-<- [clRIFFHandler::ScanFile]
              ->-> [clRIFFLISTChunk::TagsToLIST]
              <-<- [clRIFFLISTChunk::TagsToLIST]
              Writing Chunk Header 'LIST' Length: 188 ChunkPosition: 44 ChunkDataPos: 52
              Writing Chunk Header 'id3 ' Length: 12636 ChunkPosition: 240 ChunkDataPos: 248
              <-<- [clWaveDecoder::WriteIDTags]
              Got drive Z:\ ** not CD Rom, type: 4 [cddaSCSIPassTru::FillDriveList]
              Meta Final Pass
              dBpoweramp Release 15 Digital Audio Extraction Log from 07 May 2014 01:13
              Drive & Settings
              Encoder: Wave -compression="PCM"
              Extraction Log
              RIFF Header 'RIFF' Length: 12876 FormType 'WAVE'
              Got Chunk 'fmt ' Length: 16 RiffSizeLeft: 12864 ChunkPosition: 12
              Got Chunk 'data' Length: 0 RiffSizeLeft: 12840 ChunkPosition: 36
              Got Chunk 'LIST' Length: 188 RiffSizeLeft: 12832 ChunkPosition: 44
              Got Chunk 'id3 ' Length: 12636 RiffSizeLeft: 12636 ChunkPosition: 240
              ->-> [clRIFFLISTChunk::InitFrom]
              Found Correct INFO ID, decoding LIST chunk:
              <-<- [clRIFFLISTChunk::InitFrom]
              Writing Chunk Header 'LIST' Length: 182 ChunkPosition: 44 ChunkDataPos: 52
              Writing Chunk Header 'id3 ' Length: 12636 ChunkPosition: 234 ChunkDataPos: 242
              Writing Chunk Header 'id3 ' Length: 12778 ChunkPosition: 234 ChunkDataPos: 242
                • 46143
                Do you have any security or anti malware, or anti phishing software? if so try to disable it as a test.
                • Fleetway
                  • Apr 2014
                  • 15
                  I have security software by Comodo installed. I disabled it and ran the CD Ripper again - exact same problem.
                    • 46143
                    Take an existing audio file and convert it to wave (no debug required), what is the audio length of the wave file?
                    • Fleetway
                      • Apr 2014
                      • 15
                      I used the Music Converter to change a normal audio file from Flac to Wave - this worked as normal, with both audio lengths being 3:44.
                      I used the Music Converter to change one of these zero-length files from Flac to Wave - this had no effect, audio length remained 0 in both versions.
                        • 46143
                        Try run:
                        http://forum.dbpoweramp.com/showthre...rom-the-System
                        Clear all the settings and files, then reinstall dBpoweramp and try ripping using default settings (no changes).
                        • Fleetway
                          • Apr 2014
                          • 15
                          Do I need to uninstall dbpoweramp first and then run this program, or will it nuke everything on its own?
                          EDIT: How long does this program usually take? As soon as I pressed 'reset' I was given a completion notice very much instantly. Is that normal? My Start Menu dbpoweramp shotcuts remained but the links were dead, so it seemed to have worked.
                          • Fleetway
                            • Apr 2014
                            • 15
                            I used the program anyway (twice, once as Admin and once normally, as described on the forum) and then reinstalled R15. Audio files are still reading zero for track length! The same is happening to multiple CDs.
                            For experiment, I've also tried ripping the same CD I've just tested with the CD Ripper with now with Windows Media Player instead and that has worked successfully.
                              • 46143
                              If you rip a popular CD it verifies correctly with AccurateRip?
