Manual offset input
  • luiss
    Manual offset input
    Hello,
    Im still testing dbpoweramp and i like it.
    I've been reading about that is not possible to manually enter the drive offset value and have to use accuraterip to do so.
    It is the next dbpoweramp version allow us to manually enter the offset value of our drive?
    Thank you
    • 46198
    Re: Manual offset input
    Why would you want to?
    • luiss
      What if for some weird reason i have dbpoweramp on a computer with no internet, dedicated just to rip. Or i have only some few weird cd not available in the database. I just want to be sure that internet won't be an obstacle.
        • 6189
        Once dbpa is installed and setup up (with an internet connection), the disk offset will be set and doesn't change afterwards (the offset is for your disk drive, *not* each CD). Then even without the internet you'll be able to rip CDs (entering your metadata manually of course). And without the internet, there is no "database" whether the CD is weird/rare or not. The metadata/artwork "database" is reached via the internet.
        • luiss
          i know, i just want it to manually setup the driver offset
          • eaglescout1998
            • Apr 2009
            • 203
            AccurateRip REQUIRES an active Internet connection to communicate with the database. Without that connection, it's impossible to know whether your rips are accurate.
