Annoying Popping Noise at the beginning of each music track
  • JUST.B
    • Nov 2012
    • 13
    Hi, I have been ripping my cds to flac files, but I have noticed whilst playing music through popcorn hour over hdmi cable, that just before the track starts there is a popping noise.
    I was wondering why this is and how do I get rid of it ?
    Help would be much appreciated
    • 44036
    Re: Annoying Popping Noise at the beginning of each music track
    It is possibly the popcorn is either non-gapless or is not decoding the flac file correctly, you can try the flac files in foobar on your pc to see if it can play the files without issue.
    • JUST.B
      • Nov 2012
      • 13
      Ok thanks Spoon I will try Foobar
      • JUST.B
        • Nov 2012
        • 13
        Hi Spoon, I tried music tracks on Foobar and Flac files played back ok, so must be like you said popcorn hour not playing Flac files properly.
        Thanks for that, for a moment I thought I was going to have to rerip all the cds I ripped but they must be ok then.
