Problems with configuring AccurateRip
  • Jan-Erik
    • Feb 2013
    I’ve been using dBpoweramp CD ripper for a year or two with a Dell pc without any problems at all.
    But then I got a new PC (Samsung series 9, with a Samsung “Slim External DVD Writer” TSSTcorp – CDDVDW SU-208BU and windows 8) and now it seems to be a problem to find a disc that can be used for offset detection. Out of approx. 100 cd I've got 5 that was said could be used to configure AccurateRip, but none of them worked: "This Key Disc cannot be used for offset detection it does not match the AccurateRip stored disc, or your drive does not exist in AccurateRip and this disc has multiole prssingsbstored. Please try a different Key Disc”
    Can anybody help?
    • 46221
    Re: Problems with configuring AccurateRip
    The key discs cannot be used if the discs have multiple pressings stored, so it is best trying newer released discs which are less likely to have multiple pressings. (note this is only because your drive is not yet listed, once listed any matching keydisc can be used).
    • Jan-Erik
      • Feb 2013
      But when will my drive be listed? Or du you have any suggestions of what kind of disc I should try?
      • dbfan
        • Jan 2011
        • 937
        Insert all the ones you own until it configures
