Cover Art Doesn't Stick
  • klystron
    • Feb 2013
    • 20
    I have two CD"s which, after they are ripped, and then opened in my media player,
    show different cover art than I selected (same artist, different art) in CD Ripper.
    Out of over 800 CD's, these are the only two which behave this way.
    I have deleted the artist and all associated files (twice), from my music files (and from the media player),
    and repeated the ripping process, but same problem occurs.
    When the ripping is finished, the correct art is showing up at the bottom right of CD Ripper.
    Any suggestions as to how to fix this?
  • Porcus
    • Feb 2007
    • 792
    Re: Cover Art Doesn't Stick
    If your media player is Windows Media Player, then it messes up. That is a "feature" in Microsoftish language, and somewhere it can be turned off.
    Otherwise, it might be that there are more than one image, and one player selects the front cover embedded and another will select the folder.jpg file. Open in a tagger and view.
    • klystron
      • Feb 2013
      • 20
      Sorry, should have said, my media player is J River Media Jukebox. If there is another image I can't find it. Would you recommend a tagger, and also tell me if the tagger can be used to imbed different image?
      • TedSmith
        • Jun 2012
        • 21
        mp3tag (http://www.mp3tag.de/en/) (despite its name) is a very useful general purpose tagger. I actually can't imagine not using more than one tagger: they each have their strengths and weaknesses, but I like using mp3tag to see what's really going on.
        • klystron
          • Feb 2013
          • 20
          Would still like to hear whether or not a tagger like mp3tag can handle replacing existing cover art image?
          Since I have never used one, am also wondering if there are user help links available?
          thanks all
            thanks all
            yes, mp3tag can replace exisiting cover art with the art of your choice.
