Is there a faster way to rip CDs that are not in Accurate Rip?
  • davetroy
    • Feb 2013
    I am in the process of ripping my CD collection which contains several older (mid-1980s) and somewhat obscure CDs that are apparently not in the Accurate Rip database. The ripping of these CDs takes a long time because it goes through two Accurate Rip passes, then two Ultra Secure passes. Ripping a one-hour CD could take upwards of 20-25 minutes.
    Is there a way to safely speed up this process without losing data? Would I bypass those first two passes and go right to Ultra Secure once I establish that a CD is not in Accurate Rip? Can I skip Ultra Secure and assume the Accurate Rip passes were just as secure? I know that sometimes, after Ultra Secure, dbPowerAmp fixes frames, so I don't think I'd want to skip that part. Also, is there a way to tell if a CD is in the Accurate Rip database before starting the ripping process?
    Thanks for your help.
    Dave
    • 46198
    Re: Is there a faster way to rip CDs that are not in Accurate Rip?
    If you have a drive which supports c2 pointers well, such as a plextor, then you do not need the ultra passes.
    • davetroy
      • Feb 2013
      Thanks. It does. So just enable C2 and disable Ultra?
      Dave
      • Porcus
        • Feb 2007
        • 792
        Originally posted by davetroy
        So just enable C2
        You need a drive that supports it. http://www.daefeatures.co.uk/ used to be an indication.
        For CDs not in AccurateRip, you have the following options:
        - measures that increase security. That could compensate for multiple re-reads. C2 support is one such. (Paradoxially, it may take longer time with C2 because such a drive is more prone to detect genuine errors. Don't complain! ;-) )
        - more drives and/or measures that speed up. A few drives -- most (?) Plextor's, maybe some others, I would not trust that -- could be told to flush the cache. Without that, a re-read operation must first read so much that the cache is overwritten (otherwise the drive would just fetch the potentially wrong samples from its cache over again).
        - patience! Myself I would happily leave troublesome CDs unattended overnight.
        - measures that automatize the job. User bhoar here is discounting out some CD changer robots, if he has more left:
        http://forum.dbpoweramp.com/showthre...ply-discounted
