Annoying Popping Noise between each music track ?
  • JUST.B
    • Nov 2012
    • 13
    Hello all,
    I have been using dbpoweramp to rip my cds into wave music files and I have noticed that after each track has finished there is a annoying Click or Pop noise, this is on all the tracks I have ripped not just a few of them.
    I did use EAC (Exact Audio Copy) program before I started using dbpoweramp and never got the noise between tracks using that, so I thought maybe it is the dbpoweramp ID tag on these wav files that is causing problems because EAC does not ad on ID tag on their wav files.
    I rather like dbpoweramp it is a lot quicker to copy cds and seems to have less errors reported than EAC and not so complicated to setup.
    Please could someone help out.
  • dbfan
    • Jan 2011
    • 937
    Re: Annoying Popping Noise between each music track ?
    Your player does not read wave files correctly (it reads to tag chunk as audio) you need to disable wave tagging, this can be done in dBpoweramp configuration >> codecs >> advanced
    • JUST.B
      • Nov 2012
      • 13
      Hi mrspoons, thanks for reply.
      I am new to dbpoweramp so not sure how exactly to delete wav tagging, is it I go to Wave ID Tagging Tag Creation & put it as None in Tag Creation. Is that all I do then, do I leave all the rest alone in that section ?
      Also I noticed if you press Options button and go to Meta Data & ID Tag if you press Options there is a Box below that says
      Disable Tag Writing, does this Box need ticking too ?
        Correct, set to none just for wave.
        no
        • JUST.B
          • Nov 2012
          • 13
          Thanks a lot Spoon, Great help, no more annoying Pops between tracks !
