Ripping Speed
  • Thg6276
    • Aug 2008
    • 187
    Ripping Speed
    Good day,
    Is the ripping speed very important as paramater.
    It is settled as maximum
    What is the best ?
    Maximum or lower ?
  • pablogm123
    • May 2012
    • 86
    Re: Ripping Speed
    It depends on drive you are using and discs conditions. There are drives which rips better at higher speeds, and other rips better at lower speeds. Just rip a somewhat damaged CD at several speeds, and select the one which returns less C2 errors, or none at all. For a real Plextor drive, perhaps 24x is the most equilibrated speed.
