dbpoweramp stops running
  • russiebear
    • Oct 2012
    Can anybody help please!!
    I'm running a purchased copy of the programme on both my laptop and home pc. My PC, which runs vista, was happily ripping cd's until i got the message, "dbpoweramp has stopped working", the programme then closes down. I've tried uninstalling it and then re-installing it, I tried a new download and installed that, to no avail. I did have a trial copy on my pc but never used. My laptop is still working. I cannot get the programme to run on my pc. Anybody got any ideas?
    Many thanks,
    Russ
    • 46198
    Re: dbpoweramp stops running
    What are you ripping to?
    Are you using R14.3?
    • russiebear
      • Oct 2012
      Yes, i'm using 14.3. I'm ripping music from cd's to an external hard drive using flac lossless level 5. As soon as i open the programme i get the message dbpoweramp cd ripper has stopped working. As i mentioned previously, it has worked perfectly well for over a week and has suddenly just stopped
        • 46198
        Start it without a CD disc in the drive, does it start?
        • russiebear
          • Oct 2012
          yes, the programme starts, when i then place a disc in the drive it fails
          • dbfan
            • Jan 2011
            • 937
            Under the metadata drop menu, uncheck all except freedb, if that allows a disc to be inserted, add the others one at a time, insert a different cd so it gets live from the internet
            • russiebear
              • Oct 2012
              mrspoonsi,
              thank you very much, that did it. I appreciate your help,
              cheers, russ
