CD Riper 14.3 HELP needed - Correct Settings for highest possible sound quality
  • stgomes
    • Sep 2012
    Hi, just purchased dBPowerAmp CD Riper 14.3 to rip my CD's with the maximum possible quality.
    The only thing I am looking for is to Rip in BEST of the BEST Sound Quality.
    Can you send me the step by step settings for this ? I am not a SW expert, so your help would be highly appreciated.
    Not sure if you need this info but I'm sending it just in case:
    TOSHIBA Portege R830-17P Laptop with Windows 7 Pro SP1 operating system (64-bit).
    Intel(R) Core(TM) i3-2330M CPU @ 2.20 GHz
    4,00 GB Memory
    DVD Drive is Matshita DVD-RAM UJ8A2ES.
    Hope you can help, otherwise I will be lost in the tons of settings available.
    Regards, Steven
    Re: CD Riper 14.3 HELP needed - Correct Settings for highest possible sound quality
    See:
