When ripping CD's does not get gaps between tracks correct on some
  • rmcadam
    • Aug 2011
    When ripping some CD's upon playback.
    Playback will stop before a track has completed playing, then upon the start of the next track the end of the previous track will finish leading into the next track.
    Is this issue fixable?
  • dbfan
    • Jan 2011
    • 937
    Re: When ripping CD's does not get gaps between tracks correct on some
    It is more likely the cd has been mastered incorrectly, or you have a faulty drive which is reporting the toc incorrectly.
    • rmcadam
      • Aug 2011
      Hi spoonsi just to let you know I tracked the problem finally to my computer audio playback software settings(XXhighend). All is good now and dbpoweramp was incorrectly blamed.
      I have ripped and converted to Wav hundreds of CD's and no problems at all with them using dbpoweramp.
