How do I get the ripper to add "graphic_front_cover" comment to the METADATA block (VORBIS_COMMENT). Its value should be the same as the METADATA block (PICTURE).
This is because, my receiver will only display the 'album art' when it is found in the METADATA block (VORBIS_COMMENT).
Thank you.
Thank you.
