is AccurateRip offline?
  • pcalv
    • Feb 2007
    • 52
    #46
    Re: is AccurateRip offline?
    Seems to be down again for me also
    • s.gleissner
      Originally posted by pin64
      Does anyone know of a router that definitely works that we can create a static route to?
      No, im down again, too :yawn:
      • mickel
        • 11
        #48
        Worked for me again for a couple of hours. Now it's down again. My neighbor who is on a different ISP than me hasn't had any problems at all connecting. So the conclusion seems to be to change ISP. That's swell. :(
        the issue seems to be one of routing issues which effect some people some of the time.
        I'd change that to most of the time for the last three days.
        • onionjack
          I'd second that. :(
          • s.gleissner
            Ok, after two reboots and reactivating of IPv6, i got a connection again. So it has nothing to do with IPv6, i think.
            Here is my traceroute to www.accuraterip.com (it now can be compared with my last one from page 1):
            Routenverfolgung zu accuraterip.com [89.238.133.247] über maximal 30 Abschnitte:
            1 <1 ms <1 ms <1 ms fritz.box [x.x.x.x]
            2 37 ms 38 ms 39 ms y.y.fra.de.hansenet.net [y.y.y.y]
            3 37 ms 37 ms 36 ms ge-7-2-2-0.xd02.fra.de.hansenet.net [62.109.71.78]
            4 37 ms 37 ms 37 ms ae1-0.pr03.decix.de.hansenet.net [213.191.66.142]
            5 39 ms 39 ms 37 ms de-cix.ohtele.com [80.81.192.165]
            6 56 ms 58 ms 57 ms xe-3-3-3031.bb1.ams1.nl.gbxs.net [193.27.64.150]
            7 57 ms 57 ms 56 ms vlan3333.bb1.man1.uk.gbxs.net [77.243.185.29]
            8 57 ms 59 ms 57 ms no-rdns-yet.ohtele.com [89.238.140.121]
            9 1915 ms 56 ms 57 ms no-rdns-yet.ohtele.com [89.238.133.247]
            Ablaufverfolgung beendet.
              I have made a change, if you are having difficulties, please try again.
              • mickel
                • 11
                #52
                Ok. Spoon. Don't know exactly when you made the change but i've been able to connect for about an hour now. Let's hope it stays that way. Otherwise i'll let you know :D
                Again. Thanks for looking in to it. Highly appreciated.
                • theprimogenitor
                  • Sep 2009
                  #53
                  Working again in Scotland :komisch9:
                  thanks
                    If someone cannot access www.accuraterip.com within the next hour from this post date please post your IP address (visit http://www.whatsmyip.org/ to find out)
                    • pcalv
                      • Feb 2007
                      • 52
                      #55
                      working a treat for me now thanks spoon
                        I suspect the issue is not solved and will return for some people.
                        • mickel
                          • 11
                          #57
                          That sounds sinister.:teufel8::smile2:
                          Well. If the problem comes back, i'll provide my IP.
                          • TLBradbury
                            • Apr 2011
                            • 16
                            #58
                            I'm down again! :cry:
                            50.46.224.248 (as reported by WhatsMyIP.org)
                            I started another disc and when I came back I discovered that I was not getting AccurateRip verification (the previous disc completed fine).
                            • h8ten
                              As of today 24-07-2011 02:00h CET the AccurateRip database and the AccurateRip website are both still off-line for me.
                              Is this a consequence of the server being migrated to new hardware? Of is there some other problem.
                              Here is my IP address: 83.163.238.201
                              Walter
                              • funplexedrunner
                                It's touch and go for me. I rip a CD and it works fine, then the next one, it is offline. The website works for me, but when I click to view the key discs, my browser says it cannot make a connection.
                                My IP is 50.102.35.203
