High volume squelch between tracks
  • lth1
    • May 2011
    I am getting a very loud squelch between tracks when ripping files to the SD card for my wav player, this does not occur with rips when using FreeRip.
    Cordially,
    Lee Hankins
    • 46222
    Re: High volume squelch between tracks
    dBpoweramp Configuration >> Codecs >> Advanced
    and disable the ID Tagging for Wave (your wav player is not able to read wave files as they are designed, ie a file of chunks, instead it thinks the whole file is audio).
