Wrong rip when the Sample offset is defined
  • gourze
    • Feb 2011
    Hello,
    I have the following problem when I rip a CD:
    If I reset the field "Sample Offset" in the CD ROM configuration and I rip any tracks of the Titanic CD, I got an accurate confidence of 132
    dBpoweramp Release 14 Digital Audio Extraction Log from mercredi 2 mars 2011 09:00
    Drive & Settings
    Ripping with drive 'F: [ATAPI - DVD A DH20A3H ]', Drive offset: 0, Overread Lead-in/out: No
    AccurateRip: Active, Using C2: Yes, Cache: None, FUA Cache Invalidate: No
    Encoder: FLAC -compression-level-8
    DSP Effects / Actions: -dspeffect1="ID Tag Processing=-case={qt}0{qt} -exportart={qt}(none){qt} -importart={qt}(none){qt} -maxart={qt}(any){qt} -arttojpg" -dspeffect2="ReplayGain=-albummode={qt}0{qt}"
    Extraction Log
    Track 1: Ripped LBA 0 to 13730 (3:03) in 0:14. Filename: E:\Music\James Horner\Titanic\01 Never an Absolution.flac
    AccurateRip: Accurate (confidence 132) [Pass 1]
    CRC32: E77D69AA AccurateRip CRC: C6CC8A70 [DiscID: 015-0022ee0c-019ca8fa-df10fd0f-1]
    AccurateRip Verified Using Pressing Offset +6, Confidence 132 [old crc c6cc8a70]
    1 Tracks Ripped Accurately
    After that, if I save the sample offset value as suggested to +6 and I rip again the same track, I got an accurate confidence of 1
    dBpoweramp Release 14 Digital Audio Extraction Log from mercredi 2 mars 2011 09:04
    Drive & Settings
    Ripping with drive 'F: [ATAPI - DVD A DH20A3H ]', Drive offset: 6, Overread Lead-in/out: No
    Extraction Log
    Track 1: Ripped LBA 0 to 13730 (3:03) in 0:09. Filename: E:\Music\James Horner\Titanic\01 Never an Absolution.flac
    AccurateRip: Accurate (confidence 2) [Pass 1]
    CRC32: 9BA48C16 AccurateRip CRC: 9F14E33A (NEW) [DiscID: 015-0022ee0c-019ca8fa-df10fd0f-1]
    This problem occurs on any track, on any CD, on 2 different drives and it is easy to reproduce.
    I try to use the second drive and I get the same issue with a different offset:
    dBpoweramp Release 14 Digital Audio Extraction Log from jeudi 3 mars 2011 12:52
    Drive & Settings
    Ripping with drive 'H: [LITE-ON - BD B LH-2B1S ]', Drive offset: 0, Overread Lead-in/out: No
    Extraction Log
    Track 1: Ripped LBA 0 to 13730 (3:03) in 0:15. Filename: E:\Music\James Horner\Titanic\01 Never an Absolution.flac
    CRC32: 780FD08D AccurateRip CRC: C6CC8A70 [DiscID: 015-0022ee0c-019ca8fa-df10fd0f-1]
    AccurateRip Verified Using Pressing Offset +618, Confidence 132 [old crc c6cc8a70]
    dBpoweramp Release 14 Digital Audio Extraction Log from jeudi 3 mars 2011 12:53
    Drive & Settings
    Ripping with drive 'H: [LITE-ON - BD B LH-2B1S ]', Drive offset: 618, Overread Lead-in/out: No
    Extraction Log
    Track 1: Ripped LBA 0 to 13730 (3:03) in 0:12. Filename: E:\Music\James Horner\Titanic\01 Never an Absolution.flac
    If I compare the .wav files in hexa, I see a difference of 24 bytes between the two files.
    Any idea how to solve the issue ?
    Gourze
    • 46160
    Re: Wrong rip when the Sample offset is defined
    Try R14.1 in the beta section, the log files are more consise (and will match across all pressings) it might shed a little light on it.
    • gourze
      • Feb 2011
      After the installation of the R14.1 beta, I ripped the first track with the offset sample set to +6 and a got the same result that with the R14:
      Code:
      Track 1:  Ripped LBA 0 to 13730 (3:03) in 0:18. Filename: E:\Music\James Horner\Titanic (Music from the Motion Picture)\01 James Horner - Never an Absolution.flac
        CRC32: 9BA48C16     AccurateRip CRC: 9F14E33A (CRCv2)     [DiscID: 015-0022ee0c-019ca8fa-df10fd0f-1]
        AccurateRip Verified Confidence 2 [CRCv2 9f14e33a]
        AccurateRip Verified Confidence 132 [CRCv1 c6cc8a70]
        AccurateRip Verified Confidence 70 [CRCv1 29d45685], Using Pressing Offset +220
        AccurateRip Verified Confidence 2 [CRCv2 ada5f5ab], Using Pressing Offset +362
        AccurateRip Verified Confidence 64 [CRCv1 811f7b74], Using Pressing Offset +362
        AccurateRip Verified Confidence 37 [CRCv1 d619a7b8], Using Pressing Offset +431
      When the accurate offset was not initialized, I got the following log:
      Code:
      Track 1:  Ripped LBA 0 to 13730 (3:03) in 0:38. Filename: E:\Music\James Horner\Titanic (Music from the Motion Picture)\01 James Horner - Never an Absolution.flac
        Secure  [Pass 1 & 2]
        CRC32: E77D69AA     AccurateRip CRC: 00000000     [DiscID: 015-0022ee0c-019ca8fa-df10fd0f-1]
      Gourze
        • 46160
        It does not look like the actual offset was changed, AccurateRip contains routines to stop tampering with offsets as they should not really be ever changed, especially a 14.1 can show all the pressing offsets now.
        • gourze
          • Feb 2011
          I don't understand why when I reset the accurerip I got the CRCv1 "c6cc8a70" and when I use the suggested offset +6, I got the CRCv2 "9f14e33a".
          What is the difference between CRC v1 and v2 ?
            • 46160
            If you are manually tampering with the offset then the results are going to be unpredictable.
            • gourze
              • Feb 2011
              I don't manipulate the offset manually:
              In the first case, I reset the offset (it displays "AccurateRip to find"). When I rip the CD, I got the CRC v1 "c6cc8a70"
              After that, if I put the CD again in the drive, dbpoweramp suggests me to configure the AccurateRip value. I configure it as suggested and when I rip the CD, I got the CRC v2 "9f14e33a"
                • 46160
                I understand, in which case there is a bug in R14 because it should not try to check against AccurateRip until an offset is found...I will correct for R14.1
                • gourze
                  • Feb 2011
                  Thanks a lot for your answer.
                  Just an additional comment: During calibration, the saved rip file is equivalent to an offset of 0.
                  If I userstand correctly between accuraterip v1 and v2:
                  Today, a lot of CDs were ripped and checked in crc v1. When I rip a CD with dbpoweramp R14 and upper, the confidence is compared only with the crc v2. That is why the confidence can be pretty small compared to a version using accuraterip v1.
                  In this case, can I suggest you to compute the accuraterip crc in both v1 and v2 and to add the confidence number.
                  Example:
                  For a track, if accuraterip crc v1= 132 and accuraterip crc v2=2, dbpoweramp can display "confidence 134 (132+2)"
                    • 46160
                    R14 checks against v1 and v2 CRCs and will present a v2 CRC if it is present. R14.1 will display both 132 and 2, and the other pressings.
