Ripnas essentials & AccurateRip help
  • dabob
    • Dec 2010
    • 22
    I'm not very technical so appologies if some of this doesnt make sense.
    Recently bought a Windows Home Server box to use as a music server, only to find that the only DBpoweamp software I can use is RIPNAS essentials which doesnt support accuraterip or C2 error pointers. Or at least I dont think it does ?
    Can anyone suggest what my best options would be ?
    The options I think I have are:
    1) sell it and buy a windows 7 PC and use that.
    2) use a windows 7 PC to do the ripping part and hold or transfer the data onto my WHS box.
    3) format the HDD's in the WHS box and install windows 7. I imagin there may be problems with the OS/hardware incompatibility as it only has 4 USB connections and an ESATA, no connections for keyboard/screen unless I could use USB variants ? By the way it's an Acer Easystore H340.
    4) is it possible to maybe run a windows 7 OS on a flash drive and use the HDD's in the WHS to write to ? or make it into a dual boot machine ??
    Is there any advantage/disadvantage to using a windows 7 PC as a music server ? I went for WHS because the RIPNAS box uses it so assumed it was the best OS to have but it seems only the RIPNAS complete box solution can do accuraterip/C2 pointers with WHS (which isnt blatantly obvious
    Any help or suggestions appreciated. I havent started ripping my collection yet as I want to get it setup properly first do I'm not wasting my time.
    Bob
    • 46198
    Re: Ripnas essentials & AccurateRip help
    5) Connect to the WHS box through remote desktop and install dBpoweramp Reference and rip through remote desktop.
    • dabob
      • Dec 2010
      • 22
      Thanks, I thought that would be the best option. Is there any way of upgrading as I have already paid out my $45 for the essentials ?
        • 46198
        Email your order number and I can swap the order to Ref R14.
        • dabob
          • Dec 2010
          • 22
          Thanks for that, much appreciated.
          Just another thought (bearing in mind i'm not techie). Would it be possible to run DBpoweamp on say a laptop/desktop, ripping to the WHS box via a DVD drive which is connected to the WHS box, or would the DVD drive have to be connected to the laptop/desktop ?
          Bob
            • 46198
            The dvd drive has to be local to the machine.
